Wheel removal-not amused. - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 17 (permalink) Old 02-16-2016, 05:47 PM Thread Starter
Thumbs down Wheel removal-not amused.
So,I got paint flaking off my rear pulley,no problem whip the wheel off,remove pulley then prep and repaint it. Easy eh? Not on your life,jack up bike onto blocks,slacken rear wheel nut and withdraw spindle. No,not unless you remove the heatshields and exhaust system first. Why wasnt the spindle inserted from the left side so it could be removed without touching the pipes.Things like this are so bloody infuriating.
2008 Suzuki B King,2010 Vegas 8 Ball,2006 BMW Z4.
goon is offline
post #2 of 17 (permalink) Old 02-16-2016, 05:51 PM
LILMAGS500's Avatar
Slide your axle to the right just a bit and remove the lock / oval washer , it is grooved , then pull the axle out the left side ... Easy .
LILMAGS500 is offline
post #3 of 17 (permalink) Old 02-16-2016, 07:46 PM
Marius's Avatar
I just went through this on my hammer, and initially was ticked that I had to slide the stock mufflers off as part of the process, but in the end it turned out to be easy. I don't know how that would work with aftermarket pipes, if the mufflers don't separate from the rest of the exhaust system. That could be quiet a pain.
Still, shaft drive bikes are much more complex, and there are even belt driven ones that are way worse than victories. We have it reasonably easy I think.
2007 Victory Hammer (Nuclear Sunset)
2012 Vstrom Adventure 650
2006 Suzuki M50 (Black) - Traded
1995 Mustang GT... Work in Progress...
Marius is offline
post #4 of 17 (permalink) Old 02-16-2016, 09:32 PM
RoteBaron's Avatar
I'm with you mate. The blasted engineer that designed it NEVER will and never intended to work on it so why the hell would they care right! It sure isn't the first time I've seen this kind of stupid. You have to take half the front of a Honda car off to change the freaking alternator. Hey, it LOOKED good on "paper". Bunch of maroons I say... ;-)
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg (Soon to go)
Victory High Flow Air Filter
Soon to tune with Maximus
2017 Highball - Suede Nuclear Sunset Orange
Xbow exhaust, High flow air filter, Lame stage 1 update (MEH)
RoteBaron is offline
post #5 of 17 (permalink) Old 02-16-2016, 09:48 PM
djh3's Avatar
When I went to work @ a race shop one of the old school guys that worked there told me this little ditty. Behind every good train wreck is and engineer. Sad but oh so true. You have to wonder whay folks with so much brains are so inept at common sense.
2013 XCT added Jan 2015
djh3 is offline
post #6 of 17 (permalink) Old 02-16-2016, 10:43 PM
SilvrT's Avatar
Did you read the service manual instructions for removing the rear wheel?
Doesn't sound like it.
1. Secure motorcycle in a stand with straps.
2. Place a platform jack under the engine. Elevate the
motorcycle enough to take the weight off the rear
wheel, but still leave the wheel touching the platform.
NOTE: Muffler removal is not required.
3. Remove the lower shock bolt and lower pushrod bolts
from the swingarm.
4. Raise the motorcycle high enough to gain access to the
axle nut. Remove axle nut.
5. Using a soft-faced mallet, tap axle to the right until
retaining plate is clear of the swingarm and remove
plate.
6. Remove axle from right side of swing arm.
NOTE: Axle adjuster nuts do not have to be loosened or
removed, however, belt tension and alignment must be
inspected after assembly.
7. Elevate the motorcycle until the swingarm shock
mount is raised a minimum of 12 inches (305 mm).
8. Remove the drive belt-side wheel spacer and
disengage drive belt from rear sprocket.
9. Remove rear caliper carrier assembly from swing arm.
10. Secure brake caliper assembly to swing arm with tie
strap or support it so it does not hang by the brake line.
11. Remove rear wheel from left side of the motorcycle
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #7 of 17 (permalink) Old 02-17-2016, 06:14 AM
dentdave's Avatar
from the swingarm.
plate.
#3 easiest way to lower the rear wheel with the bags and mufflers in place. This is how I've been doing it.
SilvrT likes this.
David
www.dentdave.com
2012 Cross Country Tour
IBA # 33520 - 1040 in 24, 04 / 2008
1036 in 24, 10 / 2014
Michelin Primacy Alpin PA3 ZP 195/55/16
dentdave is offline
post #8 of 17 (permalink) Old 02-17-2016, 06:16 AM
Jamming's Avatar
I hear ya Brother! I've even sat in the design chair and wondered
Whiskey Tango Foxtrot...over?
I eat, breathe, live, love and ride motorcycles.
4 wheels move the body, 2 wheels move the soul.
Wiseco fueler, Lloyds timing gear +4, Thrush modded mufflers and LLoyds air filter.
Jamming is offline
post #9 of 17 (permalink) Old 02-17-2016, 07:09 AM
LILMAGS500's Avatar
Isn't Goon riding a Vegas ? His axle should slide right out the left side after removing the oval lock . He will need to drop the swing arm down to remove the wheel , but the axle will still slide right out .
post #10 of 17 (permalink) Old 02-17-2016, 07:11 AM
LILMAGS500's Avatar
Personally , I think the design is flawless . Very simple .
SilvrT likes this.
