LED Headlight - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 21 (permalink) Old 02-29-2016, 12:49 PM Thread Starter
Default LED Headlight
if you have one of them high dollar LED lights you might want to spend $35 bucks to save your $400 dollar light
Cee Baileys | Victory Triangular Design Headlight Guard
post #2 of 21 (permalink) Old 03-01-2016, 11:47 PM
dixon4420's Avatar
how is that cover held on?
dixon4420 is offline
post #3 of 21 (permalink) Old 03-02-2016, 04:51 AM
vindex1963's Avatar
It says 3M Dual lock. That's a fancy way of saying two sided tape.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #4 of 21 (permalink) Old 03-02-2016, 05:03 AM
Krisd's Avatar
Got one- from Cee Baileys- they are great. Sticks on just fine, never been lose or close. Fits like a glove too- most don't even notice it.
Vinnie- it's those push interlocking gizmos, not tape, so it clicks on and off. Not Velcro, the other stuff. That way one can easily remove and clean it and the headlight.
vindex1963 likes this.
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
post #5 of 21 (permalink) Old 03-02-2016, 05:37 AM
Has this protective cover effected the light beam or projection at all?
post #6 of 21 (permalink) Old 03-02-2016, 05:42 AM
Krisd's Avatar
No I don't think so, definitely not during the day.
2012 Hammer S
Krisd is offline
post #7 of 21 (permalink) Old 03-02-2016, 08:10 AM
RGP
Made me laugh two sided tape doesn't sell like 3m Dual Lock.......the add men strike again !
vindex1963 and SubDude like this.
RGP is offline
post #8 of 21 (permalink) Old 03-02-2016, 08:40 AM
dixon4420's Avatar
Would you be able to get a close up pic of yours on and off so we can see what it looks like. The pics on all the sites suck
post #9 of 21 (permalink) Old 03-02-2016, 12:26 PM Thread Starter
its clear plastic. what more you want. Heavy duty velcro.
you can see the white dot that hold it in place.
The Cee Bailey's headlight guard is made from thick aircraft-grade acrylic.Whipping out the calipers, the guards are not surprisingly made of the same 1/8th inch (0.125Ē) acrylic that is used for the side windows of most light airplanes.
Rollin had one on his vision on all his trips especially on the Alaska trips
Cee Bailey's Headlight Cover Review - webBikeWorld
post #10 of 21 (permalink) Old 03-02-2016, 02:31 PM
Krisd's Avatar
OK will try to remember to do this tonight- if not over the weekend.
2012 Hammer S
Krisd is offline
