How about a water cooled pushrod engine - Victory Forums - Victory Motorcycle Forum
 8Likes
post #1 of 26 (permalink) Old 02-29-2016, 01:27 PM Thread Starter
Default How about a water cooled pushrod engine
As the title says, what if victory decided to change the 106 to a water cooled pushrod engine? The engine height could be lower. I don't see the advantage of using an overhead cam engine.
vcc14 is offline
post #2 of 26 (permalink) Old 02-29-2016, 06:09 PM
gibson's Avatar
push rods is old out dated technology. all your high end expensive sports cars use overhead cams. you can use a program to advance timing or retard while you are running.
DirtyDan likes this.
2012 Fireball Jackpot
gibson is offline
post #3 of 26 (permalink) Old 02-29-2016, 09:36 PM
Don't tell that to Hemi and small block owners. Ever hear about the Motus Gibson? OHV is anything but dead.
post #4 of 26 (permalink) Old 02-29-2016, 09:46 PM Thread Starter
Just because they use it, doesn't make it better. Overhead cam is also dated technology.
vcc14 is offline
post #5 of 26 (permalink) Old 02-29-2016, 10:28 PM
There's really not much new mechanically under the sun. New developments seem to be digital ones. IMO many are put onto cars and bikes just coz they can, not coz they are needed or wanted, like keyless ignition.
post #6 of 26 (permalink) Old 02-29-2016, 10:51 PM
Motorbikerx's Avatar
pigs might fly...oh hang on, they do!
https://youtu.be/0bztbETb2xU
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #7 of 26 (permalink) Old 03-01-2016, 03:12 AM
gibson's Avatar
overhead cam engine can run faster without worrying if the valve train will float and put a valve into the piston. the height of the motor is the same there really is no difference, unless you really want to back to a flat head Ford motor. There is a good example of wasted horsepower. Could not get enough air and fuel into the engine.
gibson is offline
post #8 of 26 (permalink) Old 03-01-2016, 04:11 AM
cam shafts, rockers, pushrods. Overhead cam, in block cam, it's all becoming obsolete VERY soon. Koeningsegg (and i'm sure other companies too) have developed camless engines. welcome to the 21st century!
https://www.youtube.com/watch?v=OZWeNPi2XkE
--weezl-- is offline
post #9 of 26 (permalink) Old 03-01-2016, 04:26 AM
BP6666VR's Avatar
Yup solenoids operated valves ... I think it was covered on another thread ... Good stuff hey ?? Austrian ingenuity ... Cool hey ??
Edit; Oups Swedish ....
Cross Country Tour 2014 [B]
BP6666VR is offline
post #10 of 26 (permalink) Old 03-01-2016, 08:00 AM
kevinx's Avatar
y reason companies use push rods; including car companies. Is because the knuckle draggers of this planet can't live without them.
Pushrods have more parts to fail, every opening event is slightly different, create engine packaging issues, and make multi valve sytems way too complex
kevinx is offline
