14 Cross Country Oil Leak WTF - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 03-12-2016, 12:22 PM Thread Starter
MLC
MLC's Avatar
Default 14 Cross Country Oil Leak WTF
I know there are other post about oil leaks but I needed to vent somewhere.. Bike has been parked at my brother since late November 2 weeks ago went on an 80 mile ride enjoying the mild weather in Mass, now today i got a pic and message from my brother about the bike leaking oil. I traded in my HD for Victory to avoid these little headaches WTF.. Mileage 10,354 oil change was done in August and i had a pcv and dyno tuning done in September with KMC no leaks then?
Llyodz timing wheel +4, PCV, Llyodz filter, 1/4 Turn throttle ring, D&D exhaust, KMC dyno tuned.
Black HID headlight
MLC is offline
post #2 of 15 (permalink) Old 03-12-2016, 12:55 PM
LILMAGS500's Avatar
Did your brother pinpoint the leak ? Could be the cam cover , mine was leaking right from the factory , simple gasket issue .
LILMAGS500 is offline
post #3 of 15 (permalink) Old 03-12-2016, 01:01 PM
Pauljp's Avatar
Wow, that doesn't happen very often.
Only a couple of things I can think of... loose oil filter, was the filter gasket lubed prior to installation? It should only be installed hand tight, check it.
The other is the drain plug... Is it tightened to 15 ft/lbs? Was the washer changed?
These are the only common things that could have happened. Something loosened while you were on your last ride. Shouldn't be too hard to check.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #4 of 15 (permalink) Old 03-12-2016, 01:02 PM
Originally Posted by MLC View Post
Attachment 172961
That's depressing looking.
Maybe something simple such as a shifter shaft seal that failed or popped out?
Couple of loose screws in the primary taking the tension off the gasket. Oil drain plug & gasket loose. That sort of stuff. Vic's don't have a reputation for springing leaks as far as I know, which is a good thing...
Just a thought..
You didn't make the mistake of parking it next to an older HD while you were out on your last ride did you? I try to keep my Vic away from my HD's as I don' t want them picking up any bad habits....
Then if I had severely mistreated my brother growing up or never paid him that 20 I lost in a bet 20 yrs ago, or if he was noted for having a great sense of humor.. I'd not stress till I had a first hand look.
We used to dump bags of rice under our friends Honda's and then go into the bar and tell them their bike was leaking all over the sidewalk. You never know what is up till you poke your head under it. Be sure to check your oil level before you start it. Goes without saying of course.
Hope it is something minor.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #5 of 15 (permalink) Old 03-12-2016, 01:19 PM Thread Starter
MLC
MLC's Avatar
I will be able to check the bike out tomorrow and yes that pic was very depressing was supposed to go ride tomorrow. As i said i thought i was done with oil leaks when i switched to Victory.. It does get parked over the winter next to 4 HD's.. Thanks for the responses i'm hoping its either the filter or drain plug. I'll post after its fixed.
Black HID headlight
MLC is offline
post #6 of 15 (permalink) Old 03-12-2016, 03:01 PM
SilvrT's Avatar
Maybe brother is playing a joke on ya...
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #7 of 15 (permalink) Old 03-12-2016, 05:42 PM
I'll go with brother.
Look at the size of the leak and there is no way a filter or cam cover could leak that much. Maybe a primary dought it.
If there were HD's in garage I bet one puked oil on start up and they moved your bike over it
Bad funnie Brother
post #8 of 15 (permalink) Old 03-12-2016, 07:50 PM
BP6666VR's Avatar
Ohhhhh I wanna see the end of this .. Good luck MLC ... Keep us posted what a oilbath like that could have caused ... Let's hope for all the above mentioned easy to fix things ...
TaPaTaLk for VIC forum
Cross Country Tour 2014 [B]
BP6666VR is offline
post #9 of 15 (permalink) Old 03-12-2016, 08:12 PM
RoteBaron's Avatar
Default Can appreciate your pain
Attachment 172961
Can appreciate your pain. Does your brother have a Charley or a Triumph? ;-) Seriously, I pulled my cam cover and replaced put a Lloydz timing gear on, put he cover on (no new gasket) and it still doesn't leak (I even have the reusable gasket still in the bag). As the Brits might say "I think he having you off!"
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg (Soon to go)
Victory High Flow Air Filter
Soon to tune with Maximus
2017 Highball - Suede Nuclear Sunset Orange
Xbow exhaust, High flow air filter, Lame stage 1 update (MEH)
RoteBaron is offline
post #10 of 15 (permalink) Old 03-13-2016, 07:31 AM
DirtyDan's Avatar
My vote is that your brother is a practical joker. I see there is oil dry put down right away so it doesn't stain his precious floor. Does he ride a Harley?
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
