MSD Ignition Info Wanted - Victory Forums - Victory Motorcycle Forum
 7Likes
post #1 of 12 (permalink) Old 04-24-2016, 09:11 AM Thread Starter
Default MSD Ignition Info Wanted
I've read that the MSD ignition coil set return next to a zero increase in actual hp or torque. But, they simply look so good I keep thinking about them anyway. I don't understand why they're so expensive though. Here is my question;
Do they interfere (add noise) with radio/XM/bluetooth performance in any way or cause any other performance problems?
My bike is a CCT and I regularly use my Sena bluetooth setup.
Thank You,
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #2 of 12 (permalink) Old 04-24-2016, 12:21 PM
if your not racing and don't have a big motor
There not worth the money.
Lot of promises with only seat of the pant dreams
Buy some good plug wires and save the $300 dollars for a trip this summer
post #3 of 12 (permalink) Old 04-24-2016, 08:24 PM Thread Starter
I know you're right VJ, thank you. Pretty sure I'll follow that advise.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
post #4 of 12 (permalink) Old 04-25-2016, 01:17 AM
BP6666VR's Avatar
When I placed my second order to plan my bolt-on power upgrades
PC 5 / Lloydz Adjustable Timing System& gasket / Torque Tube Intake Blue Re-Usable Hi-Flow Filter (WITH NITROUS HOOKUP) for 08-up Models (w/ Idle Air Valve Assembly)
then the MSD was on that list, and despite the power gain is only 1 HP, i still was considering the MSD, but luckily the company who sold me all this stuff was so kind NOT TO DO IT ....
so i didn't ....
only my experience on the web ..
Chattanooga Mark likes this.
Cross Country Tour 2014 [B]
BP6666VR is online now
post #5 of 12 (permalink) Old 04-25-2016, 01:26 AM
Motorbikerx's Avatar
Red leads are just as visual, I'm staying with black myself.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is online now
post #6 of 12 (permalink) Old 04-25-2016, 04:29 AM
gibson's Avatar
These are Accel plug wires if you are going for the look. I would not change the coil on my bike it is not worth the time or money. No performance gain unless you are running a blower and drag racing.
2012 Fireball Jackpot
gibson is offline
post #7 of 12 (permalink) Old 04-25-2016, 05:33 AM
I also stuck some red plug wires on last winter. They look cool and cost all of $35......and for some reason I never took a pic of them
PaiN is online now
post #8 of 12 (permalink) Old 04-25-2016, 10:12 PM Thread Starter
The BFC colors are red and blue so I already have one red and one blue plug wire. I purchased these from Withdoctors a couple years ago.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
post #9 of 12 (permalink) Old 04-25-2016, 10:24 PM
BP6666VR's Avatar
Originally Posted by gibson View Post
Attachment 178594
About a year ago there was 1 member that went for a DYNO tune and the thingy they clip around your plug wires ??
Well ACCEL plug wires did not give any @ enough electrical readout ( insulation is to good aparently ), so they had to put some stock wires on there to do the DYNO ... How cool is that product ... ACCEL wires are on my bucket order list ...
If it's true or not I do not know, but I seem to remember also it was a HD tuner ... Not a VIC tuner that are on this forum ..
TaPaTaLk for VIC forum
post #10 of 12 (permalink) Old 04-29-2016, 05:45 PM
Vendor
witchdoctor's Avatar
For what its worth we make the MSD coil kits. I tell people that on the newer -08 up bikes you won't see any HP gains. They are pretty much for looks. On the 07 and older bikes they do help with cleaning up the idle a bit and do provide some gains on bikes running on the rich side. As far as wires go we make most of them as well. People do say the wires help and double as looking good. Hope this helps.
witchdoctor is offline
