Clutch cable tip - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 2 Post By Motorbikerx
post #1 of 10 (permalink) Old 04-28-2016, 02:12 PM Thread Starter
Default Clutch cable tip
found this on FB where a guy put two O-Rings on end to keep it centered in arm. He says his was always off to one side and was scared it might break some day. Good thinking
File Type: jpg 12920465_1071200889604627_959229587293013761_n.jpg (19.4 KB, 65 views)
post #2 of 10 (permalink) Old 04-28-2016, 06:33 PM
Motorbikerx's Avatar
Wouldn't that create friction at a point that needs to be kept moly greased
Motorbikerx is offline
post #3 of 10 (permalink) Old 04-29-2016, 09:24 AM
Foto Joe's Avatar
I don't think so, the O-rings should fit in between the tangs on the clutch actuator arm. When the clutch is engaged it'll just sit there under no load like it always does, it's just that the O-rings keep it centered.
Personally I don't think this is an issue as like I said, when the clutch is engaged it's not under load so when you do pull the clutch lever and it comes under load it's not like it was being jammed sideways and is binding. I think the man found a solution for a problem that doesn't exist but if it works for him that's what counts.
@"[email protected]_ _ _
Ambition is a poor excuse for not having enough sense to be lazy.
2017 Cross Country
Stage 1 & Tri-Ovals
Foto Joe is offline
post #4 of 10 (permalink) Old 05-08-2016, 11:41 PM
Spent an hour or so on a rainy day cleaning and lubing my clutch cable and its now easy peasy and smooth as silk.
2008 Suzuki B King,2010 Vegas 8 Ball,2006 BMW Z4.
goon is offline
post #5 of 10 (permalink) Old 05-09-2016, 06:54 AM
BP6666VR's Avatar
Goon .. Stock cable or not ?? I changed for a Barnett cable and it is coated with Teflon the steal and "hose" so I thought I remember VIC says NOT to lube your cable
But if it is smoother now THEN GOOD ON YA .....
OP VJ, i like the picture and idea but I think it is more to tinker around then solving a problem .... But I think it looks great, small details make a great bike .... Your bike so to speak
TaPaTaLk for VIC forum
Cross Country Tour 2014 [B]
BP6666VR is offline
post #6 of 10 (permalink) Old 05-09-2016, 08:33 AM
an hour?...what did you do for the other 50 minutes, its a ten minute job.
depot picker and vindex1963 like this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #7 of 10 (permalink) Old 05-09-2016, 11:58 AM Thread Starter
think the o-rings are for keeping the lug in the center of the arm nothing more then that.
Pull your clutch in and see if the lug moves sideways.
Just trying to help
post #8 of 10 (permalink) Old 05-15-2016, 02:52 AM
Yes it is a 10 minute job if you get my drift but done over an hour doing other things,if you try 10 minutes continuous squirting oil down the cable there would be oil all over the shop.
goon is offline
post #9 of 10 (permalink) Old 05-15-2016, 06:34 AM
LILMAGS500's Avatar
I never lube the cable inside the casing , I only lube the cable ends .
LILMAGS500 is offline
post #10 of 10 (permalink) Old 05-15-2016, 06:46 AM
Cable shouldn't be lubed,only the ends cleaned and moly greased.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
