Rear brake pads - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 03-09-2010, 09:37 AM Thread Starter
New Member
Default Rear brake pads
Is it necessary to remove the rear wheel on an 07 Hammer to replace the rear brake pads?
hammerheadz is offline
post #2 of 2 (permalink) Old 03-09-2010, 10:33 AM
NOEMTZ's Avatar
Negative, the pads will slide up and out after removing pin clip and pin itself. I usually use a screwdriver to open my calipers a bit before removing the old ones to make room for the new thicker pads. You can do it in less then 10 minutes.
www.noemtz.com
NOEMTZ is offline
