possible Fuel pump issues - Victory Forums - Victory Motorcycle Forum
 7Likes
post #1 of 25 (permalink) Old 08-17-2017, 09:12 AM Thread Starter
jkcerda's Avatar
Default possible Fuel pump issues
got a new to me 06 Vegas that had been sitting for the last 2 years, already changed spark plugs and drained old fuel to add new, still no go, the bike is at a friends house 1.5 hours away so it's a bit hard to get there to diagnose it properly.
I found this on e-flay
WALBRO EFI Fuel Pump Victory Vegas 2003-2015 Polaris 8-Ball Jackpot 2520700
is that basically what I need, I am willing to try and do the labor myself but I am low on funds and can't afford to make mistakes buying the wrong thing. I should have the bike with me this weekend.
thanks for your help.
jkcerda is offline
post #2 of 25 (permalink) Old 08-17-2017, 09:57 AM
Bigmike17's Avatar
Before you buy the fuel pump, can you hear the fuel system prime when you turn on the red ignition switch?
an alternative:
New Genuine Walbro Fuel Pump Direct Fit EFI Victory Vegas Jackpot / 8 Ball / Premium / Low Premium / XTRM 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014 2015 2016 2017, Replaces Victory 2520700, 2520733, 2520284, 2520394, Walbro F2000010
jkcerda likes this.
2014 Cross Country Tour
Freedom Performance exhaust, Lloydz VFC and a Lloydz Intake/filter, Lloydz ATS.
Bigmike17 is offline
post #3 of 25 (permalink) Old 08-17-2017, 10:14 AM
How old is battery does it crank over fast or real slow. If your friend has battery charger put it on battery. Low voltage charge.
Go to auto store and rent a fuel pump tester. Most places its free.
jkcerda likes this.
post #4 of 25 (permalink) Old 08-17-2017, 10:16 AM
watch several times before jumping in
jkcerda likes this.
post #5 of 25 (permalink) Old 08-17-2017, 10:17 AM
when you have tank off clean throttle body
jkcerda likes this.
post #6 of 25 (permalink) Old 08-18-2017, 08:55 AM Thread Starter
jkcerda's Avatar
got almost no pressure BUT I am having a hard time making sure the connection is tight due to how tight the area is, I am not sure the fitting is sealing properly there. going to lift tank up a bit to see if I can tighten it up
jkcerda is offline
post #7 of 25 (permalink) Old 08-18-2017, 10:51 AM Thread Starter
jkcerda's Avatar
should I get the pump AND the pressure regulator?
New Fuel Pressure Regulator Direct Fit EFI Victory Vegas Jackpot / 8 Ball / Premium / Low Premium / XTRM 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014 2015 2016 2017, Replaces Victory 2520700, 2520733, 2520284, 2520394, Walbro F20000107, Wal
jkcerda is offline
post #8 of 25 (permalink) Old 08-18-2017, 12:33 PM
Honda East Toledo's Avatar
This bike cranking over fine? These pumps you should be able to hear prime.
Battery fully charged? these bikes need a hearty/healthy charged battery.
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #9 of 25 (permalink) Old 08-18-2017, 12:38 PM Thread Starter
jkcerda's Avatar
Originally Posted by Honda East Toledo View Post
1.This bike cranking over fine?
2.These pumps you should be able to hear prime.
3.Battery fully charged? these bikes need a hearty/healthy charged battery.
1.yes
2. I do hear it
3 yes
having a hard time getting the fuel pressure fitting to sit tight, it reads less than 10lbs right now but since I can't tell if it's sealed properly I don't know if I am getting a good reading. ordered pump & pressure regulator, going to lift tank up so I can properly set the fitting and get a proper reading
jkcerda is offline
post #10 of 25 (permalink) Old 08-18-2017, 12:43 PM
What do you mean by "no go?" Describe to us exactly what is and isn't happening. Have you cleaned and tightened the battery terminals? Fully charged the battery? Do you hear the pump when you turn the key? Do you wait for it to stop priming? Is there spark? Removed the old gas and put in new? We could use more info before we can zero in in the problem.
