Rear brake soft - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 14 (permalink) Old 09-07-2017, 07:33 AM Thread Starter
Hayabuso's Avatar
Default Rear brake soft
Hello everyone, I have a problem with my victory vision of 2012 with abs. It turns out that when I brake with the rear brake standing, the lever is loose and I have to pump twice so that the bike brakes with the rear lever. I have purged the brake circuit but it remains the same. Do you think that you can be the master bomb? has happened to any? Thanks very much
Hayabuso is offline
post #2 of 14 (permalink) Old 09-07-2017, 07:47 AM
NOEMTZ's Avatar
Need to bleed the right front and then the left front calipers using the rear brake foot pedal and bleeders that are about center of calipers...not the top bleeders.
www.noemtz.com
NOEMTZ is offline
post #3 of 14 (permalink) Old 09-07-2017, 07:54 AM Thread Starter
Hayabuso's Avatar
yesterday I did that thinking that it would be air on the circuit but still the same. can be the pressure modulator or the rear master pump
Hayabuso is offline
post #4 of 14 (permalink) Old 09-07-2017, 08:10 AM
NOEMTZ's Avatar
Maybe. But common problem on Vision and most likely bleeding issue. Did you use a friend to pump brake pedal and hold it down while you open and release pressure? Then repeat until all air is out? Make sure you never run out of fluid.
visionjohnny likes this.
www.noemtz.com
NOEMTZ is offline
post #5 of 14 (permalink) Old 09-07-2017, 08:35 AM Thread Starter
Hayabuso's Avatar
Yesterday I was in the workshop and I did it with the mechanic. still the same. we purge the front right, left and rear brake.
Hayabuso is offline
post #6 of 14 (permalink) Old 09-07-2017, 08:49 AM Thread Starter
Hayabuso's Avatar
I think the vision pedal is very long and the force exerted is a lot for the pump and the pump seals may be bad
Hayabuso is offline
post #7 of 14 (permalink) Old 09-07-2017, 02:07 PM
Turn bars to left.
Sit on floor and pump rear brake pedal hold down.
Open center bleeder on right front caliper.
After you open and fluid or air comes out close bleeder. NOT THE TOP ONE
Now let up rear pedal.
Check master cylinder for fluid you want it close to full. Put cover back on.
Now pump rear brake hold down.
open center bleeder then close it.
Now let rear pedal up and see if you have pedal.
no need to open rear bleeder
post #8 of 14 (permalink) Old 09-07-2017, 03:25 PM
id-man's Avatar
I think the vision pedal is very long and the force exerted is a lot for the pump and the pump seals may be baD
This is the next suspect. Has to be a rebuild kit available.
Cape Cod, MA
2010 Cross Country "Scrolly"
www.VicWrapz.com
id-man is offline
post #9 of 14 (permalink) Old 09-07-2017, 03:44 PM Thread Starter
Hayabuso's Avatar
thanks for the reply. yesterday I did this in the workshop with the mechanic. but the problem remains the same.
I wanted to know if anyone has the same problem and had to change the master pump or some pressure modulator. Thank you
Hayabuso is offline
post #10 of 14 (permalink) Old 09-07-2017, 03:46 PM Thread Starter
Hayabuso's Avatar
that's what I wanted an aviable kit. Do you know where I can buy it online? or the pump model?Thanks
Hayabuso is offline
