Check engine light - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By Pauljp
  • 1 Post By visionjohnny
post #1 of 5 (permalink) Old 09-08-2017, 01:32 PM Thread Starter
Tony.v's Avatar
Default Check engine light
So yesterday on my way home I accelerated hard coming out of a corner and then costed to a stop at the next intersection at a red light. As I came to a stop I glanced down and my "Check engine light" was on. Bike is running great and no unusual sounds to be heard. I was only a few min from home so I continued on. I figured maybe it was a one off and that it might go away by morning but not so. Soon as I started the bike it stayed on.
Any thoughts as to what might be the issue? no error code is displayed on the DIC
Thanks as always for your help
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
My YouTube channel with some great ride videos https://www.youtube.com/channel/UCZQ...zKe8NanTYPyiiA
Tony.v is offline
post #2 of 5 (permalink) Old 09-08-2017, 04:29 PM
Pauljp's Avatar
I'm thinking since you accelerated hard around a corner the RPM's were high and if your regulator is on the fritz then you would have an overvoltage. That would cause the light to come on.
What's your voltmeter showing during high revs? If it's higher than 15 volts it's your regulator.
visionjohnny likes this.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #3 of 5 (permalink) Old 09-08-2017, 05:50 PM
Motorbikerx's Avatar
Yep second that.
Mine recently went out when i was fanging it.
Stock regs not a real good unit anyway.
I upgraded mine through Jack at Roadstercycle.
But yeah check what volts are going into your battery and fix it before you cook the battery as well.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 5 (permalink) Old 09-08-2017, 06:04 PM Thread Starter
Tony.v's Avatar
Thanks that sounds right as yes the voltage gauge does sit up around 16volts and I've seen it fluctuate a fair bit as I ride but I thought it was normal.given it's under warranty I will just get them to replace it. I'll look at ordering one of the better ones for later if this is something I should worry about?
Tony.v is offline
post #5 of 5 (permalink) Old 09-08-2017, 07:02 PM
Go to dealer for warranty
Motorbikerx likes this.
