Need Advice - Victory Forums - Victory Motorcycle Forum
 3Likes
  • 1 Post By BBob
  • 1 Post By BBob
  • 1 Post By NOEMTZ
post #1 of 10 (permalink) Old 10-07-2017, 11:52 PM Thread Starter
Default Need Advice
Need some help, I installed LLoydz VM1 cams, Torque Tubes, PCV with a map from Vicshop on my 2012 Vegas 8 ball. I drove about 200 miles after that and no issues. Today noticed that when I was in second and first gear in low rpm, the RPM dropped and looks like the bike shutoff. The bike restarted fine drove perfectly and again after I slowed down in first and second gear when I reved, it shut off and I was able to restart again. Any ideas on what could be happening? Could it be due to bike running rich or lean from the map? Suggestions are much appreciated
fak005 is offline
post #2 of 10 (permalink) Old 10-08-2017, 12:26 AM
Originally Posted by fak005 View Post
Need some help, I installed LLoydz VM1 cams, Torque Tubes, PCV with a map from Vicshop. I drove about 200 miles after that and no issues. Today noticed that when I was in second and first gear in low rpm, the RPM dropped and looks like the bike shutoff. The bike restarted fine drove perfectly and again after I slowed down in first and second gear when I reved, it shut off and I was able to restart again. Any ideas on what could be happening? Could it be due to bike running rich or lean from the map? Suggestions are much appreciated
As always when this happens start by remaking your battery connections. Be sure they are clean and tight. Sounds like they may be loose which gives the ecm fits.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #3 of 10 (permalink) Old 10-08-2017, 12:56 AM
If you put the year and model in your sig line and your location in under your forum name it helps when trying to help you.
Joe gave good advice. Check your battery terminal connections to start with. Depending on what you have a reset on the TPS might help.
visionjohnny likes this.
post #4 of 10 (permalink) Old 10-08-2017, 06:54 AM
If your bike wasn't doing this stall prior to the tune, then that's likely the cause. I'd bet your not getting proper fueling in the low rpm's(probably everywhere) on the canned map. Your upgrades are substantial, especially the cams. Since you spent the money and time on the "mechanicals" you should really do the most important part and have your setup properly dyno tuned. Besides fixing the stall, you'll gain performance and know your not doing any harm to your engine.
post #5 of 10 (permalink) Old 10-08-2017, 07:27 AM Thread Starter
Thank you, my apologies, it's a 2012 Vegas 8 Ball
fak005 is offline
post #6 of 10 (permalink) Old 10-08-2017, 09:28 AM
I'd go back and check your PC-V connections too and make sure they are fully snapped in and connected.
Also, it's great that we now know what you have, but won't in the future and will have to ask all over again unless you put that info in your signature line using the forum Control Panel.
post #7 of 10 (permalink) Old 10-08-2017, 12:29 PM
Also be sure that the ground to the PCV is placed as it shows in the install drawing. Most fuel controllers appreciate that. It gives them the best chance of trouble free operation.
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #8 of 10 (permalink) Old 10-09-2017, 06:24 PM
NOEMTZ's Avatar
If you installed an IAV as well....try removing it (go back to stock set up on IAC) and running without it.
www.noemtz.com
NOEMTZ is offline
post #9 of 10 (permalink) Old 10-10-2017, 02:36 AM Thread Starter
Please see attached map I got from vicshop, do you think I am getting too much fuel that may be causing the stall. I noticed it happens at low rpm and when blippin, can you pls take a look at snap shot of the fuel and ignition maps thx
fak005 is offline
post #10 of 10 (permalink) Old 10-10-2017, 11:54 AM
Victorys don't like blipping the throttle. Stop doing it
