Belt Deflection spec - Victory Forums - Victory Motorcycle Forum
 21Likes
post #1 of 26 (permalink) Old 01-25-2018, 10:30 AM Thread Starter
Default Belt Deflection spec
So according to my owners manual the belt deflection spec for the 2016 Hammer S (after 500 miles) is 6mm, +/- .5mm. I noticed that the 2008 Hammer service manual that I recently downloaded calls for 12mm. That's a huge difference. Granted the 2008 manual is citing the 100Ci motor, but sill I wouldn't think the belt deflection would be much different. I also see that Victory changed the rear shock from 3.9" to 3", which changed the ride height specs, so maybe that's a factor. With my bike currently just over 100 miles, I have right now about 10 to 12 mm deflection (cold belt) with the rear tire NOT off the ground, and after doing some modest riding the belt being warm is snug.
Usually raising the rear off the ground will increase chain/belt slack. I'm not concerned about the current belt deflection right now, but after 500 miles I will do an adjustment. Can anyone confirm that the 6mm spec is correct for a 2016 model year? That seems really tight given that its with the rear tire elevated and with the bike and belt being cold.
https://www.victoryforums.com/8-victo...t-tension.html
https://www.victoryforums.com/36-vict...e-screwed.html
And by the way, I checked the tire pressures and both front and rear were in the mid 20's psi even though the dealer assured me he had prep the bike and inflated the tires per spec of 38/41.
2016 Hammer S...stock
Spacecoast is offline
post #2 of 26 (permalink) Old 01-25-2018, 06:33 PM
BP6666VR's Avatar
Yup you go over that bike inside out, and follow that manual... It is a good one.... I printed it in A3 size for easy reading....
Drive Belt = it isn't that difficult, but if the steel frames manual says "lift the rear wheel" than that is what you should do, also to spin it freely in reverse and then forward
If you can twist the belt 90į with 2 finger both ways it should be fine
I set my tires at 45 PSI.... Nothing wrong with that, don't run them under 35 PSI , coz you will wear them out faster
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 26 (permalink) Old 01-25-2018, 06:47 PM Thread Starter
That's the question...which manual? My owners manual which cites 6mm, or that 2008 service manual which cites 12mm?
Honestly, based on reading the threads that I posted, and based on how my belt behaves and the current deflection I won't be going with the 6mm spec.
post #4 of 26 (permalink) Old 01-25-2018, 06:52 PM
BP6666VR's Avatar
Just try 12 then? Or the 90į with 2 finger that works GOOD.... You don't want too tight or too loose for squiking noises ... But I think you have to raise your wheel of the floor ....
See the Divice I home made I use it on both vics and my friend HD
BP6666VR is offline
post #5 of 26 (permalink) Old 01-25-2018, 07:36 PM
I would err on the side of caution and go with the looser spec. A too-tight belt can ruin engine pulley bearings.
BBob is online now
post #6 of 26 (permalink) Old 01-25-2018, 09:08 PM
cra-z1's Avatar
I 2nd that. I run mine a little losser than recommended. I know the kingpin low had different specs than the std model. Not sure about your model.
Coeur d Alene Idaho, formally MPLS. 2009 KingPin, 2011 KingPin 8 Ball,
cra-z1 is offline
post #7 of 26 (permalink) Old 01-25-2018, 10:21 PM
BP6666VR's Avatar
OK so if you have a 2016 then ONLY read the 2016 or "so" manuals, this means as per below, i stated in second post...
1 motorcycle in upright position
2 elevate rear wheel
3 follow the manual for deflection
As a sample picture attached for sequence.....
Anyway I have a 2013 Jackpot and follow an average of 6 to 12 mm and never had a problem
visionjohnny likes this.
BP6666VR is offline
post #8 of 26 (permalink) Old 01-25-2018, 11:09 PM
I'm going to throw a monkey wrench into these works with this...........
When hot, my belt would get guitar string tight even though I adjusted exactly to spec with a belt gauge. Got to chatting about it with MBX, whom I consider quite the Vic guru and he said loosen it until there's some slack in it when hot. Makes sense to me and I think the belt and bearings are now a lot happier. Too simple.
post #9 of 26 (permalink) Old 01-26-2018, 01:16 AM
Motorbikerx's Avatar
Yeah keep it simple.
Bike parked on stand is easy.
Poke up with your finger midway along the lower run of your belt.
If bikes cold youll have more slack, about an inch.
After a decent ride to get everything hot try poking it again and youll find its tightened up considerably but should still have some 'give' in it as you push up.
If it hasnt then its too tight and too tight is no good at all.
Better a bit loose than too tight.
After the initial break in then it should stay the same and not need to be messed with.
Dont let the place that changes your tyres mess with adjustment at all.
No need to.
Just keep it simple....
Even so I still give my belt an occasional poke just to check, Im a bit OCD that way.
Same goes for clutch freeplay too.
And I cant walk past a MIG, Oxy, or LPG bottle without checking that the tap is securely Off.
Easy to check. Keep it Simple.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 26 (permalink) Old 01-26-2018, 07:10 AM Thread Starter
I agree with you and Motobikerx. You would think that Victory would have figured this out by now and would have published an accurate spec in the owners manual. 6mm cold and with wheel off the ground would make a hot belt so tight it can't be right. So much for investing in a tension gauge tool. I'm new to belt drive systems, but just my experience in seeing how the belt changes between cold and hot tells me to be careful, and not to use the 6mm spec. I have a Yamaha FZ-09 in which the owners manual also provides an inaccurate and dangerous chain slack spec. WTF.
Kurbs likes this.
