Quicksilver Motorcycle Oil - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By vindex1963
  • 1 Post By Spacecoast
post #1 of 9 (permalink) Old 03-16-2018, 07:37 PM Thread Starter
olddad64's Avatar
Default Quicksilver Motorcycle Oil
I saw a gallon on this oil at Wal-Mart today for $28 and that's not a bad price for a Gallon of Synthetic Motorcycle Oil and was wondering if anyone knew of some who may have tried it. It has all the specs for motorcycle oil. I personally use Castrol Synthetic Motorcycle oil.
2014 Victory Cross Country Tour. Blue and Silver
Tri-Ovals--Stage 1 download--Loydz Air Filter
Sabertooth Saddle Bag Lights
LED headlights and a few custom engine/transmission goodies
olddad64 is offline
post #2 of 9 (permalink) Old 03-17-2018, 07:28 AM
I usually buy all my motorcycle oil at Walmart, but I've only seen JASO MA2 oil in quart containers.
2016 Hammer S...stock
Spacecoast is offline
post #3 of 9 (permalink) Old 03-17-2018, 09:37 PM
djh3's Avatar
Made by mercury marine. Around here a gallon of rotella t6 ful syn 5w40 runs around $21
2013 XCT added Jan 2015
djh3 is offline
post #4 of 9 (permalink) Old 03-18-2018, 09:00 AM Thread Starter
olddad64's Avatar
5w40 is a little thin weight don't you think ? Thought we were suppose to use 20W40 or 20W50
olddad64 is offline
post #5 of 9 (permalink) Old 03-18-2018, 01:05 PM
Many here use Rotella T-6 which is 5W-40 and that 5W has its advantages. It helps to aid a rapid oil flow on cold starts by circulating faster than thicker oils. It gains in viscosity as it warms to 40, so no worries. My lifters used to clatter something awful on cold starts until I switched to 5W-40. The analysis reports come back five stars, adding that there is a lot of good miles left, even after inadvertently going 7K miles on one sump full. Everything else is A-OK, including shifting.
post #6 of 9 (permalink) Old 03-18-2018, 01:59 PM
vindex1963's Avatar
A 5-40 and a 20-40 are both 40wt.
BP6666VR likes this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #7 of 9 (permalink) Old 03-18-2018, 08:50 PM
BP6666VR's Avatar
The first number is for cold or hot weather ...
5 or 10 = for cold weather
15 or 20 = for hot weather
The second number is the oil weight ... W40 or W50
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #8 of 9 (permalink) Old 03-19-2018, 02:34 PM
The first number is the initial flow weight, and the W stands for Winter.
RICZ likes this.
post #9 of 9 (permalink) Old 03-19-2018, 03:06 PM
vindex1963's Avatar
@rodhotter know the exact temps each is designated.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
