belt mileage - Page 2 - Victory Forums - Victory Motorcycle Forum
 31Likes
post #11 of 28 (permalink) Old 04-04-2018, 03:51 PM
depot picker's Avatar
IMHO, when hot, you don't need slack but you don't need it guitar string tight.
depot picker is offline
post #12 of 28 (permalink) Old 04-05-2018, 06:29 AM
whooshbang's Avatar
Done the same. I Slackened the belt tension off a bit. when my belt is stone cold it's fairly slack, almost as much as a motorcycle chain. After a nice ride it's tight but not "oh my goodness it's gonna snap" tight.
2015 Victory Judge
whooshbang is offline
post #13 of 28 (permalink) Old 04-05-2018, 09:27 AM
Honda East Toledo's Avatar
We had a issue with a gent on his older Vegas, took him three belts before he figured out what he was doing wrong.....You cant just toss the belt on and wing it, you need the info out of the service manual and a decent belt tension gauge, Motion Pro makes a good one and I think the VIC one may still be available. I know when the techs out back do a belt they check, double check, triple check, THEN road test and then check again. Them belts are not cheap.
visionjohnny likes this.
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #14 of 28 (permalink) Old 04-05-2018, 09:46 AM
Like many, when I bought my XCT I was concerned about the belt adjustments. I ordered a gauge a month or two later. By the time I got around to checking it, I had a pretty clear picture of how it needs to be. I adjusted it and aligned it, but I never took the gauge out of the package. Still haven't. YMMV
post #15 of 28 (permalink) Old 04-05-2018, 09:57 AM
NAB
NAB's Avatar
The first belts that Victory had were pretty poor. I broke several of them. The new belts are much stronger. I don't hear anything about them braking. 10 years ago it was pretty common. I use to carry a spare on road trips. The old type of belt was soft and pliable. Easy to roll up and pack.
Riding: 2011 XC
Sold: 2003 Vegas
Totaled: 2003 TC, But it's still on the road.
Sold: 2004 TC
This is Just the list of Victory's. I have also rode and owned Honda's, Kawasaki's, Suzuki's, Harley's. Some old European bike. Can't remember the name. It was a 3 speed and I started riding on a 50cc bike that Sears sold. Some time around 1967. I have had my motorcycle license since 1969.
NAB is online now
post #16 of 28 (permalink) Old 04-05-2018, 10:28 AM
Polaris many moons ago changed the way they shipped the belts as well. They use to come folded up on themselves, till they started to realize that when they did that the belts started to fail faster.
They were cracking on the folds, so after a while they changed the boxes and ship them now unfolded.
Its the same as when you keep folding over a thin piece of metal or whatever, if you keep folding it back and fourth on its self, sooner or later it snaps.
(877)-437-1631
Like us on Facebook
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
post #17 of 28 (permalink) Old 04-05-2018, 10:58 AM
whooshbang's Avatar
yea i done the whole service manual procedure, back wheel off the ground, belt at ambient temperature, belt tension tool etc etc... still backed it off a little after.
I check my belt thoroughly and clean each groove with a toothbrush on a regular basis.... especially at the moment as the roads are kinda shitty after the winter season.
I hear ya though and i am usually a stickler for specs.... but that "guitar string" tension after a long ride.....
2015 Victory Judge
post #18 of 28 (permalink) Old 04-05-2018, 11:54 AM
GatorJoe's Avatar
Thumbs up
Originally Posted by RICZ View Post
Dumb question time.......
When hot, my belt would be guitar string tight and was correctly set to spec cold. I can't imagine that was doing the belt, pulleys and related bearings any good, so I now have adjusted the belt so there is a bit a slack when hot. I invite your collective thoughts on doing this.
I agree and have done this with all my belt drives for years ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #19 of 28 (permalink) Old 04-05-2018, 07:38 PM
Over 55K on my original belt and it still looks great. I've never, not even once, cleaned it. It was adjusted on the loose end of the spec and has never made noise either. I'm contemplating replacing it at 60K miles but the jury is still out on that.
Question:
Is the rear pulley a 'wear item"? I've read several accounts of people having to replace a worn rear pulley. Or does the rear pulley really only wear out when the belt is too tight?
I can't imagine the solid steel front pulley ever wearing out.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #20 of 28 (permalink) Old 04-05-2018, 07:43 PM
Question:
I changed the belt at 105,000 roughly, did not change the pulleys.
