Chinese knock-off LED headlight - Victory Forums - Victory Motorcycle Forum
 15Likes
post #1 of 63 (permalink) Old 06-14-2018, 08:22 PM Thread Starter
vindex1963's Avatar
Default Chinese knock-off LED headlight
These have been out for a while, what's the long term opinion? Do you still think they're good?
Here's an example of the LED headlight I'm taking about.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #2 of 63 (permalink) Old 06-14-2018, 08:35 PM
doobliss's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I believe a handful of members have bought those. Haven't heard from them in awhile... (twilight zone music)
'15 Gloss Titanium XC.
WOLO Low Tone Disc Horn
Tri-Oval Slip Ons
Black LED Headlight
Kingpin Metal Fork Guards
Ricz Lay Down Plate
Lloydz Timing Wheel & Throttle Ring
Shinhopples Grip Covers
12" Long Ride Shield
Bad Ace Billet Fork Mounted Air Deflector
Ness Signals; Amber front, Red rear
http://www.pure-gas.org/
"I leave the BUG CARNAGE on my screen , it adds character!"-LILMAGS500
doobliss is offline
post #3 of 63 (permalink) Old 06-14-2018, 08:40 PM Thread Starter
vindex1963's Avatar
Exactly why I'm asking, I have the H11 replacement LED's and one stopped working and they are $$$. I bought the above LED headlight and am installing it this weekend.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #4 of 63 (permalink) Old 06-15-2018, 12:22 PM
toejam's Avatar
Let us know how it goes, and if you think it's worth the investment.
vindex1963 likes this.
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #5 of 63 (permalink) Old 06-15-2018, 01:23 PM Thread Starter
vindex1963's Avatar
I'll install it this weekend. It also has the LED trim around the outside of the light, I didn't notice that before.
Speedblue likes this.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #6 of 63 (permalink) Old 06-15-2018, 02:05 PM
I have experience with the cheap knockoffs; they aren't as bright and they aren't built as well. I have one. I ended up buying a genuine Vic LED light. Brighter light, better quality.
broggyr is online now
post #7 of 63 (permalink) Old 06-15-2018, 11:19 PM Thread Starter
vindex1963's Avatar
40W low 60W high.
The LED H11's I had CLICK
The light pattern is wide and I'm not sure it outshines the H11 halogen I didn't have them for long but it doesn't outshine the H11 LED's I did have for low beam distance. This one lights up the sides more than the H11 LED's did.
The H11 LED's didn't last a year
LED headlight assembly compared to H11 LED bulbs.
Pro's:
Much more side to side lighting
High beam is like a search light, very confined and directed, outshines H11 LED bulb
Halo lighting really stands out
(hopefully they last more than a year)
Con's:
Not as much low beam reach
Can't change out a light if it fails.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #8 of 63 (permalink) Old 06-16-2018, 12:15 AM
Just like trying to decide to do cams, I have marinated over that headlight assembly. But I have converted the original headlight to an LED low beam and a HID high beam and I no longer hesitate to ride at night like I used to. Perfect? No, but pretty damn close and it cost less than the assembly and, as you noted, I can change out one bulb if it goes out.
post #9 of 63 (permalink) Old 06-16-2018, 01:11 AM
You can find the genuine Victory LED for around 150 online.
I did consider it but the posts I've read on this and other forums that compare it with the HID setup already on my bike people went back to HID.
It is somewhat tempting to buy one to try it but I have other bits to spend my money on first and I consider the HID to be much better than the halogen of my other bike.
post #10 of 63 (permalink) Old 06-16-2018, 04:48 AM
GatorJoe's Avatar
Thumbs up
Had 50,000 Miles and 2+ Years on the Vic LED and still worked fine when Traded .. Well worth it to me and traveled a lot of lonely Dark Roads at Night ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
