Vic with Flat Rear Tire - Victory Forums - Victory Motorcycle Forum
 7Likes
  • 4 Post By Dusty Boots
  • 2 Post By Will Pizzolato
  • 1 Post By Will Pizzolato
post #1 of 6 (permalink) Old 06-25-2018, 05:49 PM Thread Starter
Default Vic with Flat Rear Tire
Got a 2012 XC with 70K miles on it. This weekend, riding in 100 degree weather, 200 miles. Shortly thereafter, got back on bike, rear tire was flat. After a long and expensive story about getting it to an open shop on a Sunday, turns out that the tire leaked from between the bead and the rim. Tire was a Dunlop Elite 4 with 1,500 miles on it.
Any opinions/ideas about this?
Will Pizzolato is offline
post #2 of 6 (permalink) Old 06-25-2018, 05:56 PM
Dusty Boots's Avatar
Most likely a lazy tire tech didn't clean the rim bead during your last tire change!
Dusty
2013 Victory XCT - SW Ontario
Stage 1 Victory Tri Oval kit, with EFI retune
Lloydz Timing Wheel (+3)
Quarter turn throttle ring
It's never too early to plan and never too late to go!
Dusty Boots is offline
post #3 of 6 (permalink) Old 06-25-2018, 06:04 PM Thread Starter
Yea, when I looked at the bead, it looked like it had tiny pieces of rubber randomly distributed on its surface. Then in your estimation, this was not likely an issue with the tire, but with the mounting of the tire? Thanks, Will
post #4 of 6 (permalink) Old 06-25-2018, 06:20 PM
id-man's Avatar
Originally Posted by Will Pizzolato View Post
the tire leaked from between the bead and the rim - a Dunlop Elite 4 with 1,500 miles on it.
Wow, 1500 miles and it left pieces of itself married to the rim? It makes me wonder too if those shreds weren't there from some previous, very old, tire that had dried out and disintegrated so bad it glued itself to the rim and the last tire guy just said fuckit, it ain't my bike.
Cape Cod, MA
2010 Cross Country "Scrolly"
www.VicWrapz.com
id-man is offline
post #5 of 6 (permalink) Old 06-25-2018, 06:26 PM Thread Starter
That gunk might have been there from before, but not because the tire was very old and dried out. I ride 10K to 12K miles per year and get about the same distance out of the tires, so they're changed every year. But yea, I think that the guy who mounted the Dunlop did not do any prep on the rim. The new tire was mounted onto a cleaned rim.
Chattanooga Mark likes this.
Thanks, Will
2012 XR
Llyod'z Timing Gear
Lloyd'z HOH-505 Cams
Lloyd'z High Flow Air Filter
Ness Big Shots Exhaust
116/119
post #6 of 6 (permalink) Old 06-25-2018, 07:19 PM
Have to ask you change the tire every year but how often do you check the air. Hope you don't use the vic air gauge cause there junk. Most of us get a good 15K out of a rear tire if not more
