Paint code/formulation - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 15 (permalink) Old 07-13-2018, 04:54 PM Thread Starter
vin man's Avatar
Default Paint code/formulation
I purchased a used seat cowl for my 2006 Hammer. It needed to be painted to match the bike. My bike is orange - Nuclear Sunset. Paint code is P493.
I gave that info to the painter, but he had a hard time finding the right paint. He did get something, but it didn't come out right. Wondering if anyone has a good line on the formulation or way to get the right paint because I want this to match. Thanks.
visionjohnny likes this.
-Vinny
Gilbert, Arizona
2006 Hammer
2003 Vegas
vin man is offline
post #2 of 15 (permalink) Old 07-13-2018, 06:15 PM
Maybe try a shop that can scan the current color with those color match things and custom match it.
2006 bike did the shop not account for paint fade?
post #3 of 15 (permalink) Old 07-13-2018, 06:18 PM Thread Starter
vin man's Avatar
Painter took my side cover with him to make sure it matched. But it doesn't now that it is on the cover.
-Vinny
Gilbert, Arizona
2006 Hammer
2003 Vegas
vin man is offline
post #4 of 15 (permalink) Old 07-14-2018, 01:34 AM
You didn't get what you asked for so take both pieces and show him. He should get a chance to fix it to match. If he can't, find another painter. Your only other alternative is to repaint the entire bike.
Chattanooga Mark likes this.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #5 of 15 (permalink) Old 07-14-2018, 06:27 AM
WeekendRider's Avatar
Try Witchdoctors for the paint. Call if you can't find your color on their website.
WitchDoctors.com - Victory Motorcycle Parts Supplier
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #6 of 15 (permalink) Old 07-14-2018, 08:42 AM
Honda East Toledo's Avatar
Vic was very straight about the paint codes and types, usually the longer the number, the more stuff you need to add to it, some can have a base, flake and clear ON TOP of the actual color, so thats FOUR different mixes for ONE code.
But most of the colors that are just a single color have just a color and the clear.
They still have that paint and still mix it up, but its $$$$$$
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #7 of 15 (permalink) Old 07-14-2018, 10:13 PM
Bueller's Avatar
go to WD. If its not available there let me know.
16 Magnum Midwest USA
Bueller is offline
post #8 of 15 (permalink) Old 07-15-2018, 12:13 PM Thread Starter
vin man's Avatar
I am going to try the paint shop here one more time to see if they will match it without charging me for more paint. Given they have the code and a side cover with original color, I expect them to be able to match.
If not, I will try witch doctors. I don't need a lot of paint just for this one part so hoping to buy less than a quart.
-Vinny
Gilbert, Arizona
2006 Hammer
2003 Vegas
vin man is offline
post #9 of 15 (permalink) Old 07-16-2018, 12:00 AM
A quart of color would likely paint the entire bike. Your painter simply didn't do a correct or proper color match. As has been suggested, return both parts and point out the difference in a quick show and tell. In actuality, they shouldn't have ever left their shop unless you paid for a bargain basement 'close enough' job at the outset. The Polaris paint code is mostly useless to anyone outside of Polaris Industries, Victory Motorcycles division. It's an internal code for them, it means next to nothing to a body shop.
I had a local to me painter (Colors On Parade, Rossville, GA) match my gloss pearl white on two different occasions. It's an amazing match. I see a lot of color matches in my line of work. I think my Polaris paint code is 566 which for Victory simply means gloss pearl white. The painter had to use 4 base coats, 3 pearl coats and 2 or 3 clear coats but the end result is excellent regardless of the light conditions. I 'think' your color also has a metallic layer in it. If your metal flake is anything like mine, it's a very specific type, size and color. One size/type.color of metal flake does not work for all occasions and it will most definitely change the base tone, the undertone and the visual color effect of the job.
Bring the parts back and let them try it again, on their dime. If they can't or won't, your only real options are to move on to a painter who can or live with it as is.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is online now
post #10 of 15 (permalink) Old 07-16-2018, 08:16 AM
Bueller's Avatar
White is a hard paint to deal with. Witch Doctors has the kit you want. On the WD Site they have the 675 and 352 Flat White Suede frost whatever. These two kits are actually the same. Then you need the flat clear. The easy way is to buy from WD. BTW this white is a really old color from long time ago snowmobiles and etc. Very easy and a nice match. You spray the base, find the right method 2-3 coats of pearl and clear as normal but not too much or it will start to shine. Viscosity will be right on if mixed properly.
If you call the MICA company, manufacture on the paint can they are very competent and can answer any Polaris questions with authority. If you are painting the whole bike and have a trunk buy another pint of activator.
Or you can go to the dealer but their kit will be over $500.
Bueller is offline
