Ignition Switch is loose inside. - Victory Forums - Victory Motorcycle Forum
 6Likes
  • 1 Post By RICZ
  • 2 Post By 53canuck
  • 3 Post By Speedblue
post #1 of 10 (permalink) Old 07-15-2018, 12:17 PM Thread Starter
Bueller's Avatar
Default Ignition Switch is loose inside.
Sometimes when I start and run the Ipod doesn't connect. I thought this might be the connecter at the back because they are so flimsy. Turning the bike off and on has instantly cured the problem when it happens sometimes.
Yesterday I started and ran but noticed the radio screen is BLANK. This was a first and the bike was hot. I wiggled the key and didn't get anything to blink but turning it off and back on cured the problem.
Those two symptoms remind me of a low battery condition where I suspected a switch problem because wiggling the switch would sometimes allow the instrument panel to light up/ fuel pump. Sometimes nothing during the dead cell battery failure.
Can we buy a new ignition and put our lock cyl into the new switch?
16 Magnum Midwest USA
Bueller is offline
post #2 of 10 (permalink) Old 07-15-2018, 01:16 PM
Just shooting in the dark here, but have you tried squirting some contact cleaner into the lock?
RICZ is online now
post #3 of 10 (permalink) Old 07-15-2018, 06:48 PM Thread Starter
Bueller's Avatar
I have not made a real inspection yet but my experience from automotive industry tells me I may have gotten a loose/bad one. GM had a lot of bad ignitions and some lawsuits with cars shutting down by themselves.
Bueller is offline
post #4 of 10 (permalink) Old 07-15-2018, 08:04 PM
A contributing factor to that was people hanging a bunch of additional keys and crap on their ignition key chains. Too much weight and a key handle with a hole at one side, not on the center. That provided enough leverage to rotate the key.
My ignition keys have nothing attached and I carry another in my pants pocket. You all might do that too.
visionjohnny likes this.
RICZ is online now
post #5 of 10 (permalink) Old 07-15-2018, 09:19 PM
I don't believe you can change the tumblers but you can get most ignitions re-keyed to your original. Wander by a locksmith on the bike and ask them before you order.
RICZ and visionjohnny like this.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #6 of 10 (permalink) Old 07-15-2018, 10:37 PM
Default Disappearing key
I do have a lite plastic key fob on my key. Made me think of the weight thing causing problems. I was up in northern Arizona a couple of years ago and stopped to gas up, my ignition key was missing. It had fallen out of the ignition with the bike running. I like to learn the hard way. I removed the ignition switch in Page,Az. Had to barrow tools to do that. Took the complete ignitions switch and had two brand new high quality premium keys made for around $80.00, which I was actually very grateful for and very happy that's all they cost. Figured it was cheaper than renting a truck and hauling my bike home. Since then I always carry an extra key, do not hang extra keys on it, and I have an extra at home also. Since then I have also move the ignition from the side mount system up to the handlebars, which I like much better. Oh and yes the new keys have warn down and yes it will come out of the ignition switch in the run position. I personally think the Victory (China made) ignition switch is a cheaply made piece. When it fails I may wire in one from a Honda or a Suzuki, or a NAPA ignition switch.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #7 of 10 (permalink) Old 07-16-2018, 08:21 AM Thread Starter
Bueller's Avatar
They must have fixed that. I have a fob on mine and I cannot pull it out.
Bueller is offline
post #8 of 10 (permalink) Old 07-16-2018, 01:40 PM
I wonder if its the connectors on the back side of the wedge are loose
post #9 of 10 (permalink) Old 07-16-2018, 03:00 PM Thread Starter
Bueller's Avatar
Very true however there were tech pubs about faulty Switch housing for manufacturing reasons too. Intermittent failure to start see key etc. Really shitty cars and they ( GM ) even admitted to it. All the focus was in trucks SUVS.
Bueller is offline
post #10 of 10 (permalink) Old 07-23-2018, 06:20 PM Thread Starter
Bueller's Avatar
Took ignition off tonight and cleaned all around it. I didn't take apart the back two screws because I couldn't cause a single flinch so NPF. Will squirt her later.
Bueller is offline
