Fresh Is Better - Victory Forums - Victory Motorcycle Forum
 11Likes
  • 3 Post By Chattanooga Mark
  • 2 Post By RICZ
  • 4 Post By Tenax
  • 1 Post By visionjohnny
  • 1 Post By IndyVictory
post #1 of 8 (permalink) Old 07-29-2018, 07:28 PM Thread Starter
Default Fresh Is Better
I recently bought a new drive belt from Paulie at Honda East in Toledo, OH. I haven't changed it yet and I may not for a while. I only have 60K on my CCT. But it's nice to have a new one hanging in my office. What I want to post is that the belt looks like it was just made yesterday. It has a similar look like a tire that just came out of the mold. I don't know if these belts have a date code but folks, Paulie is your hook up for Victory parts. Great prices, great communication and great delivery.
Thank you Paulie
visionjohnny, SemperVee and yago20 like this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #2 of 8 (permalink) Old 07-29-2018, 09:17 PM
I wouldn't hang it up...lay it flat somewhere. Hanging it can cause it to take a "set."
visionjohnny and cruzie27 like this.
post #3 of 8 (permalink) Old 07-30-2018, 05:26 AM
TNXR's Avatar
I've been procrastinating on getting a spare belt so thanks for reminding me!
2011 Cross Roads Sunset Red
TNXR is offline
post #4 of 8 (permalink) Old 07-30-2018, 05:38 AM
vindex1963's Avatar
My spare belt is still in the package maybe I should tale it out because it being held in an oval shape. Mine is in the garage should I store it in the
house with AZ heat?
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #5 of 8 (permalink) Old 07-30-2018, 05:56 AM
house with AZ heat?
This from Gates:
Belts may be stored up to six years if properly stored at temperatures less than 85F and relative humidity less than 70%. For every 15F increase in storage temperature above 85F, the time the belt can be stored without reduced performance decreases by one-half.Belts should never be stored at temperatures above 115F. At relative humidity levels above 70%, fungus or mildew may form on stored belts. This has minimal affect on belt performance, but should be avoided if possible. When equipment is stored for prolonged periods of time (over six months), the belt tension should be relaxed so that the belt does not take a set, and the storage environment should meet the 85F and 70% or less relative humidity condition. If this is not possible, belts should be removed and stored separately in a proper environment. See pic for more info.
I've hung mine in a closet in the house on one of those thick plastic hangers so its supported by the "neck and shoulders" of the hanger.
File Type: jpg Screenshot_20180730-051255_Adobe Acrobat_1532949213601.jpg (26.6 KB, 13 views)
2016 Victory Magnum
Lloydz air filter
Ragin Cajun slipons
PowerVision CX
Tenax is offline
post #6 of 8 (permalink) Old 07-30-2018, 02:39 PM
what RICZ do not sore on hook lay it flat under your bed. Never bend it.
Keep in mind if you keep the old belt as a spare when you have to put it back on make sure you can read the name victory. The drive belt wears like a belted tire and will not last if you reverse the direction
Chattanooga Mark likes this.
post #7 of 8 (permalink) Old 07-30-2018, 09:07 PM Thread Starter
You guys rock! Mine is hanging over the side of a bookcase which means it's about half as wide as it's long. I'll move it so it's nearly a circle and lay it flat. No problem with the temperature and humidity conditions in the house.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
post #8 of 8 (permalink) Old 07-31-2018, 12:38 PM
Sounds like way too much fuss. I'll just order when I need it.
tfkp likes this.
