Front End Noise - Victory Forums - Victory Motorcycle Forum
 6Likes
post #1 of 16 (permalink) Old 08-07-2018, 08:55 PM Thread Starter
TrainedLobster's Avatar
Default Front End Noise
I'd just like to say that I fixed the noise I had coming from the front end of my bike. It's been doing it since I bought it a month ago. Didn't necessarily sound like pads, kind of a weird sound. Regardless, I bought some new pads, slapped them in (took 5 minutes, ez peazy) and did a test ride. Noise gone.
I know I know, cool story. I'm just happy and I want to tell anyone. IT WASNT BEARINGS OR BELT!
2007 Victory Vegas 8 Ball
100 CI/5 SPD
RICZ likes this.
TrainedLobster is offline
post #2 of 16 (permalink) Old 08-07-2018, 09:11 PM
BP6666VR's Avatar
Good job my friend, its a good feeling when you fixed something .....
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 16 (permalink) Old 08-07-2018, 11:12 PM
Default Ebc
I like the noise my brake pads make. I know the EBC brake pads stop much better than the ones my XR came from the factory with. Yes it bugged me at first, but I have grown use to the noise, hardly notice it now that I am on the second set of EBC pads or is it the third? Anyway with those noisey EBC brake pads up front I know that fat front tire stops much shorter than the stock bike did. Every thing has its good and bad points. Enjoy the new ride and brake pads, be sure and test them out good so you know the stopping abilities of you brake pads, be safe.
BP6666VR likes this.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #4 of 16 (permalink) Old 08-08-2018, 07:13 AM
100 CI/5 SPD
How would you describe the sound you were getting? Would you compare it to the drone of cicadas?
visionjohnny likes this.
broggyr is online now
post #5 of 16 (permalink) Old 08-08-2018, 07:56 AM Thread Starter
It was like a groan almost, and it was loud. Definitely not what I would expect bad pads to sound like (squeaky). When I inspected them, they didn't look bad either, so I don't know what the problem was. It also made the noise regardless of whether I was using the brakes.
100 CI/5 SPD
post #6 of 16 (permalink) Old 08-08-2018, 08:19 AM
My front brake pads make noise too and it's irritating and embarrassing. The heat being generated on the front pads is pretty bad and enough to leave your fingerprints if you touch the disc after a ride even without using the brakes.
I'd like to fix the problem but there are no rebuild kits for them. This winter I'll be taking the calipers apart and hopefully be able to compile the parts using a variety of kits.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #7 of 16 (permalink) Old 08-08-2018, 08:24 AM
BP6666VR's Avatar
Do you use lyndall or EBC ?
BP6666VR is offline
post #8 of 16 (permalink) Old 08-08-2018, 10:19 AM
Bigmike17's Avatar
HAHA that is the natural ambient noise here in Texas!
2014 Cross Country Tour
Freedom Performance exhaust, Lloydz VFC and a Lloydz Intake/filter, Lloydz ATS.
Bigmike17 is online now
post #9 of 16 (permalink) Old 08-08-2018, 01:31 PM
TrainedLobster Thanks for telling us.
When you install new pads you should alway lay some sandpaper lay on a flat surface and run pads across them a few times to take the glazing off them
post #10 of 16 (permalink) Old 08-08-2018, 05:23 PM
Prestaged's Avatar
I get a noise like that from my '17 Vision. Sounds like a moan -- almost like a radio in the background. Kinda' weird. It only has a few hundred miles on it as I recently bought it new and am still riding my "daily driver" most of the time.
Roger Hammon
Riverview, Florida
2017 Vision
Prestaged is offline
