Long term problems people are finding - Page 2 - Victory Forums - Victory Motorcycle Forum
 61Likes
post #11 of 27 (permalink) Old 10-12-2018, 09:40 AM
My bike has a bad fuel tank. I keep filling it but it slowly empties over the course of 200 miles.
post #12 of 27 (permalink) Old 10-12-2018, 09:54 AM
Originally Posted by BP6666VR View Post
Nah mate, just real BAD quality bolts & nuts are used on the vics, see the broken off piece ? Thats all white oxidized .... Crazyyyyy , also the rim shafts rust like that, even the engine bolts & nuts oxidate ... The exhaust is hanging of that bolt, so if this guy had loose exhaust flange bolts, all the pressure will be on that cheap ass bolt ...
I had jap bikes standing in the snow & rain & sun, all year long, ride 6 days a week .... and the bolts looked better then on these vics , garage kept .... Ha ha ha
Andre using TaPaTaLk
Not likely. That bolt is not aluminum nor does the galvanizing plating (a surface coating treatment) process put zinc into the metal, it sits on the surface. That red is rust = steel. Oxidization = oxygen = air. Air needed to get into the center of that bolt to make it rust. It was cracked/flawed. On the piece of the bolt/stud still in the bike the rust goes right to the edge on the bottom. The shiny part is the separation of the only metal that was still holding it together. Left alone it will rust as well. Any white oxidization would be confined to the outside surface and only if it had been coated with a protective layer. You can also get a silvery looking separation of metal when really cheap pot metal has been used but that's not seen on high stress pieces. It's a metal best left for decorative attachments and Hot Wheels.
In my opinion of course.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #13 of 27 (permalink) Old 10-12-2018, 01:13 PM Thread Starter
Hard part now will be getting the swingarm off and whats left of the bolt out
post #14 of 27 (permalink) Old 10-12-2018, 04:01 PM
Simple solution. Get a Mr. Fusion. See the movies "Back to the Future" for reference.
I've been wanting one of those for my truck that likes to slurp gas a little too much.
post #15 of 27 (permalink) Old 10-12-2018, 05:26 PM
BP6666VR's Avatar
Exactly
I am not sure why you say "not likely" as all the above is correct .... your post & my post ...
olddad64 likes this.
Cross Country Tour 2014 [B]
BP6666VR is online now
post #16 of 27 (permalink) Old 10-13-2018, 02:25 PM
Default seats
To me the seats do not hold up like they should. The stock first seat that came on the bike I had it recovered only after 2 or three years. Now in all fairness I do ride the bike almost every day. The Jap bikes I bought used ten years old+ and the seats were still factory, no tears etc. Now the Goldwing I bought had the seat eaten off by cows, ha, ha. So the first seat I had recovered, it lasted a good long time. Now I have got a Mustang seat a Daytripper, narrower than stock lets me sit lower to the ground. The electrical switch controls on my bike corroded up inside way to soon after about a year the way I remember it I had to take them apart, clean the green crud out then I used die-electric grease in them, been fine since. Some other little nitpick crap also. I have got a 2011 XR so it has the noisey torque limiter, I try to ignore the noise in the lower gears. Those torque limiter parts are kind of pricey, have tooooo many other things taking away my bike repair money right now, ha, ha. ........ overall I still think they are very good bikes.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #17 of 27 (permalink) Old 10-16-2018, 02:36 AM
Getting the bolt out isn't going to be the problem. Keeping the electronics safe while welding a piece of sch 40 black pipe on the broken end of the bolt with 309L stainless rod will be. Once you weld a short nipple without threads on it ( from the inside of the pipe with a low tech stick welder, 1/16 rod) the bolt will come free after it cools down, Just grab the pipe with channel locks and twist.. A shot of penetrating oil wouldn't hurt.
But making the electronics safe, That will take some time, research and effort.
Bearings and race will need to be replaced on that side after the bolt is removed.
visionjohnny likes this.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #18 of 27 (permalink) Old 10-16-2018, 01:23 PM Thread Starter
Some guy heard a bang and then said his bike was all over the road. when he got home he opened his saddle bag and found his inner bag destroyed with a peace of steel
File Type: jpg 43788286_10215554550075171_2361225281055752192_n.jpg (33.8 KB, 15 views)
File Type: jpg 44049117_10215554550595184_1485318743155277824_n.jpg (39.6 KB, 12 views)
post #19 of 27 (permalink) Old 10-16-2018, 01:37 PM
post #20 of 27 (permalink) Old 10-23-2018, 06:40 PM
BadBoyZ's Avatar
Noticed in that first pic that the support bracket under the swingarm joint is missing. Mine keeps breaking at the seam. Did you just toss it?
07 Corey Ness Jack & 09 Jack
BadBoyZ is offline
