Long term problems people are finding - Victory Forums - Victory Motorcycle Forum
 61Likes
post #1 of 27 (permalink) Old 10-02-2018, 01:46 PM Thread Starter
Default Long term problems people are finding
I'm not trying to bad mouth anyone on FB.
Last night a guy was doing general maintenance on his bike. He found this.
File Type: jpg 42916562_10205152091958315_592511848247459840_n.jpg (42.7 KB, 64 views)
post #2 of 27 (permalink) Old 10-02-2018, 01:49 PM Thread Starter
There was a guy that said he wasn't getting good mileage and lost performance. He found this. Maybe we should share more of what these guys are finding
File Type: jpg 42575656_10215569389162114_6741097092585881600_n.jpg (40.3 KB, 62 views)
post #3 of 27 (permalink) Old 10-03-2018, 05:55 AM
TNXR's Avatar
I don't do facebook or any other social media besides this forum so not really sure what is going on in pic #2. Bad oxygen sensor or something? The first pic is kind of scary.
2011 Cross Roads Sunset Red
TNXR is offline
post #4 of 27 (permalink) Old 10-03-2018, 06:36 AM
half_crazy's Avatar
Look like injectors... O-rings bad?
visionjohnny likes this.
2006 Victory Kingpin
half_crazy is offline
post #5 of 27 (permalink) Old 10-10-2018, 10:33 AM
What is the second picture item?
post #6 of 27 (permalink) Old 10-10-2018, 10:09 PM
DaveT's Avatar
Looks like a swing-arm bolt. Possibly where the rear tip-overs mate-up with the frame. Looks like the person slammed the bike down and broke the support bolt.
DaveT is offline
post #7 of 27 (permalink) Old 10-11-2018, 05:07 PM
vindex1963's Avatar
Replaced the crap plastic brake and shifter bushings with brass bushings. The slop in the levers was getting extreme.
RICZ, Speedblue and broggyr like this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #8 of 27 (permalink) Old 10-11-2018, 08:50 PM
That bolt in the first picture was over-torqued at some point and cracked it. Rusted out in the center with only the edges hanging on before the break.
As far as long term problems go I'd say my left shoulder and lower back.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #9 of 27 (permalink) Old 10-12-2018, 03:04 AM
BP6666VR's Avatar
Nah mate, just real BAD quality bolts & nuts are used on the vics, see the broken off piece ? Thats all white oxidized .... Crazyyyyy , also the rim shafts rust like that, even the engine bolts & nuts oxidate ... The exhaust is hanging of that bolt, so if this guy had loose exhaust flange bolts, all the pressure will be on that cheap ass bolt ...
I had jap bikes standing in the snow & rain & sun, all year long, ride 6 days a week .... and the bolts looked better then on these vics , garage kept .... Ha ha ha
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #10 of 27 (permalink) Old 10-12-2018, 08:23 AM
Might be helpful to others to identify each situation with more information etc? What does the photo depict ? What model, year, mileage, etc and what was done about it?
RICZ likes this.
cal_105215 is offline
