Started again on old project - Victory Forums - Victory Motorcycle Forum
 9Likes
  • 5 Post By Speedblue
  • 1 Post By BP6666VR
  • 1 Post By PaiN
  • 2 Post By TNXR
post #1 of 5 (permalink) Old 12-23-2018, 09:28 PM Thread Starter
Default Started again on old project
I have got the engine sitting in the corner of the small garage I park my Victory in. I have been telling myself I need to tear that thing down all the way. Well it's to my old 1975 850T MotoGuzzi. So today the wife went off to take the great grand daughter shopping. So after cleaning up the old Victory it hit me. Tear the little 850cc engine down. Simple engine really to take apart. Now it will be some time before it goes back together. It needs just about everything, pistons, cylinders, bearings, cam, lifters, seal kit. So it had been into before sometime in it's past. Found a few things I did not like, bolt locking plates missing, incorrect gaskets, valve hitting one piston, worn out cam. So the positive to all this is once I get the means to purchase the parts I am going to try and get the 1000cc pistons, and cylinders, and a little bit higher lift cam. If the economy improves it may all come together in the next year. Oh yes a couple of years ago to get the project going I tore it down and sent the frame in for powder coat. Since then we have moved a couple of times, changed jobs. Life happens, so this project gets pushed to the back burner usually. Been looking at post from the National Moto Guzzi Group on one of the social medias sites. Seeing all those Guzzis on there makes me want to get this old bike running again. When they run right they can be very nice to ride. When I bought this one years ago I rode it home on one cylinder, it was shot then. I had ridden the bike a couple of years before that when it ran on two cylinders. The guy had let it sit and then was moving across country. So the fun begins again.
BBob, RICZ, visionjohnny and 2 others like this.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #2 of 5 (permalink) Old 12-23-2018, 11:34 PM
You are a bear for punishment, SB. I gotta admit I have a soft spot for Guzzis too.
post #3 of 5 (permalink) Old 12-24-2018, 03:40 AM
BP6666VR's Avatar
A build thread, yes please, awsome new years resolution
Andre using TaPaTaLk
RICZ likes this.
Cross Country Tour 2014 [B]
BP6666VR is offline
post #4 of 5 (permalink) Old 12-24-2018, 06:07 AM
@Speedblue ...I always liked Guzzi bikes, imo back in the day, they more style than what Japan was sending over. I'm looking forward to you resurrecting this one..
Don't forget the pics
RICZ likes this.
post #5 of 5 (permalink) Old 01-01-2019, 04:48 AM
TNXR's Avatar
I did a bike project that I finished up a couple of years ago and loved doing it. Others on here ribbed me pretty hard for tackling a rust bucket but now I have a well running, tagged, and insured 1973 Kawasaki 175 enduro 2 smoker that I ride quite often. It was 70 degrees here yesterday and I chose to ride it over my Cross Bike! It was a fun project that kept me busy over a couple of winters and cost more money than I want to admit. Nothing professional, all paint is from a spray can in the back yard but everything mechanical was taken apart and rebuilt, cleaned, or replaced.
Before
After
RICZ and Ahoutzer like this.
2011 Cross Roads Sunset Red
TNXR is offline
