Need help asap - Victory Forums - Victory Motorcycle Forum
 19Likes
post #1 of 21 (permalink) Old 12-28-2018, 11:56 AM Thread Starter
rainman123's Avatar
Default Need help asap
Working on my girlfriend 2011 Vegas 8 ball and broke the the nipple to the gas tank is there a way to fix it or do I have to get a new fuel pump
Or will a 2012 xr fuel pump work in her bike
Thanks
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #2 of 21 (permalink) Old 12-28-2018, 11:59 AM Thread Starter
rainman123's Avatar
Here is a pic
2012 crossroad
73 sportster sold
06 rocket3 classic
post #3 of 21 (permalink) Old 12-28-2018, 12:46 PM
@RICZ came up with a way to fix these by inserting a tube inside then putting the pieces together then using a JB Weld type product to make it whole again.
He even posted pictures somewhere. Hopefully he will see my flag to him and help out.
post #4 of 21 (permalink) Old 12-28-2018, 01:14 PM
Get a piece of 1/4" steel or aluminum tubing and a drill bit that will provide a friction fit for the tubing. Empty the tank and stand it up. Carefully drill both parts. Have sweetie hold a vacuum nozzle to the tank part when drilling. Measure the depth of the hole in the tank - just the plastic portion. Measure the length of the broken off nipple and cut the tubing to the length those two add up to. Grind a taper on one end of the tubing and tap it into the top end of the nipple as shown in the photo. Remove any burrs. Place some adhesive (super glue, plastic cement, whatever) on both broken surfaces, align and tap tubing into pump body per photo. That's it!
I did that repair many years ago and it's still holding and it should, cuz it's now much stronger than before.
FYI....When removing the tank, lift it and disconnect the fuel line from the tank. Then reverse that when replacing the tank. Disconnecting from the lower end only invites breaking the nipple.
RICZ is online now
post #5 of 21 (permalink) Old 12-28-2018, 01:18 PM Thread Starter
rainman123's Avatar
Thanks a lot
2012 crossroad
73 sportster sold
06 rocket3 classic
post #6 of 21 (permalink) Old 12-28-2018, 01:28 PM
Originally Posted by rainman123 View Post
Thanks a lot
If you need more help, email me at [email protected].
Chattanooga Mark likes this.
RICZ is online now
post #7 of 21 (permalink) Old 12-29-2018, 01:18 AM
BP6666VR's Avatar
Yesssssss i remember that fix ....
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #8 of 21 (permalink) Old 12-29-2018, 09:41 AM
Rainman123,
If all else fails and you need a new fuel pump assembly, I have a new one at my house. I'm not that far from you being just east of exit 20 from I-75. I have a funeral to attend this afternoon though. The new fuel pump assembly I have is for the Cross bikes. Just let me know if you need it. You can replace it later as I don't need it right now.
7 1 6 2 5 5 9 7 1 1 is my cell number
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #9 of 21 (permalink) Old 12-29-2018, 04:51 PM Thread Starter
rainman123's Avatar
Originally Posted by Chattanooga Mark View Post
Rainman123,
I really appreciate it but haven't been able to find out if it would work on the Vegas yet
I will get in touch with you later this evening
2012 crossroad
73 sportster sold
06 rocket3 classic
post #10 of 21 (permalink) Old 12-29-2018, 05:22 PM
A 2011 Vegas and a 2012 CCT have different item numbers for the fuel pump assembly. I suspect the only change is the attached fuel filter. The formed rubber gasket is the same for both bikes so I highly suspect the fuel pump assemblies are/would be interchangeable. From looking at the diagrams on www.partspitstop.com, the Vegas fuel filter is long and thin. The CCT fuel filter looks like it could be the same filter just folded in half. Go figure.
cal_105215 likes this.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
