Using seafoam in the oil before doing a change? - Victory Forums - Victory Motorcycle Forum
 37Likes
post #1 of 49 (permalink) Old 04-02-2019, 03:41 PM Thread Starter
Tony.v's Avatar
Default Using seafoam in the oil before doing a change?
So on another forum that I used to frequent when I had my Kawasaki Voyager XII several long time riders always suggested putting some seafoam into the oil and running the bike till up to temperature before doing a change. Is that something that is recommended here? I was bad and did not do the oil change before I put the bike to bed last fall and I will be doing this right away.
Thoughts?
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
My YouTube channel with some great ride videos https://www.youtube.com/channel/UCZQ...zKe8NanTYPyiiA
Tony.v is offline
post #2 of 49 (permalink) Old 04-02-2019, 08:45 PM
There isn't a solid yes or no answer to this. It depends on the engine, age, miles, etc.
This write-up from Amsoil might shed some light so you can make an informed decision.
https://blog.amsoil.com/is-an-engine-flush-good-or-bad/
If you do decide to flush it; I would recommend this product. I think Seafoam is overrated by a lot.
post #3 of 49 (permalink) Old 04-02-2019, 08:50 PM
I read the label on a can of Seafoam I have and they recommend 1 oz. per quart in the oil. I have never done that, so no report.
post #4 of 49 (permalink) Old 04-02-2019, 09:32 PM Thread Starter
Tony.v's Avatar
Ya, it seems that it is being used. I'm just wondering if anyone here has?
Tony.v is offline
post #5 of 49 (permalink) Old 04-03-2019, 05:27 AM
TNXR's Avatar
Just because you read something on the net doesn't mean you should do it. Follow what your owners manual tells you to do and you will be fine.
half_crazy likes this.
2011 Cross Roads Sunset Red
TNXR is offline
post #6 of 49 (permalink) Old 04-03-2019, 05:46 AM
Thoughts?
I don't "Seafoam" my engine oil before a change. But I do add it before I put my XC away for winter storage. Let me say, I do oil changes at ~5k mile intervals, where ever they fall is when I do the change. I put the bike away last Nov with ~3200 miles on the oil, I put 4oz of SeaFoam in the oil(and 6oz, in a full tank of fuel) ran the bike a few miles then put it up for the winter on a trickle charger. It fired up immediately on taking out this year(as it always does ) and it is running fine. I'll do an oil and filter change at the 5k mark but won't add any SeaFoam until the end of the year, just prior to storage.
roboots21 and id-man like this.
post #7 of 49 (permalink) Old 04-03-2019, 08:53 AM Thread Starter
Tony.v's Avatar
Thank you, Thats the info I was looking for. Do you recommend warming up the oil before changing it? (running the bike) I was planning to do a flush with some extra oil I have anyhow.
Tony.v is offline
post #8 of 49 (permalink) Old 04-03-2019, 09:41 AM
Always warm the engine\oil before changing
wspollack likes this.
post #9 of 49 (permalink) Old 04-03-2019, 11:33 AM
It's best to drain the oil after returning from a LONG ride when the oil is at its hottest and all the crud is in suspension and not settled.
half_crazy and broggyr like this.
post #10 of 49 (permalink) Old 04-03-2019, 03:35 PM
Richie271's Avatar
Just be careful not to burn your hand on the hot train plug or oil as I have.
Richie271
Long Island, NY
2010 Cross Roads. Midnight Cherry.
Richie271 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Anybody using an Oil Extractor pump? amvince Victory Tech and Performance Section 62 09-04-2017 08:06 AM
LO OIL light on after oil change ToroVictory Victory Tech and Performance Section 10 08-16-2014 11:24 AM
Seafoam in oil mikiep Victory Tech and Performance Section 8 03-12-2012 12:14 PM
been doing some of my own work, whatcha think? hiballness Victory High-Ball 3 09-10-2011 10:14 PM
Wait til You See What Victory Is Doing For 2011...Can you say 106? SmattaHead Victory General Discussion 10 10-16-2010 08:07 PM
