Gurgling tank - Victory Forums - Victory Motorcycle Forum
 4Likes
  • 1 Post By RICZ
  • 2 Post By Xpresswaykid
  • 1 Post By TNXR
post #1 of 10 (permalink) Old 04-13-2019, 11:41 AM Thread Starter
Xpresswaykid's Avatar
Default Gurgling tank
After fueling up and locking the cap I hear gurgling sounds and fuel bubbling from around the cap. This is happening when the engine is off. It’s annoying because fuel is getting on the paint but is worries me that something is wrong. Any thoughts? Thanks
Xpresswaykid is offline
post #2 of 10 (permalink) Old 04-13-2019, 12:21 PM
post #3 of 10 (permalink) Old 04-13-2019, 12:55 PM
Are you leaving some air space when you fill? If you are filing to the top, the cold gas is being heated by the hot engine under the tank and is expanding.
visionjohnny likes this.
post #4 of 10 (permalink) Old 04-13-2019, 01:14 PM
Yeah sounds like overfilled and it's coming out the vent as RICZ said.
post #5 of 10 (permalink) Old 04-13-2019, 02:55 PM Thread Starter
With the kickstand down and the handlebars straight I fill the tank until the fuel just touches the underside of the bottom of the filler opening (left side only since the bike is leaning left). I thought since there is still an air gap on the right side after filling there would be enough air space for expansion. But maybe not! After riding for a few miles and allowing the fuel level to go down, it no longer a bubble out and there was no gurgling.
Thanks for the advice! I guess I’ll have to play around and see at what level I can fill the tank and not have this happen again.
RICZ and CanuckRob like this.
post #6 of 10 (permalink) Old 04-13-2019, 07:56 PM
TNXR's Avatar
I have always filled mine to where it is about to overflow and never had a venting problem out of mine.
rainman123 likes this.
2011 Cross Roads Sunset Red
TNXR is offline
post #7 of 10 (permalink) Old 04-14-2019, 08:06 AM
I think depends if you are riding afterward or letting it sit. I tend to top off high level before a trip and during but not if I'm near a stopping point.
post #8 of 10 (permalink) Old 04-14-2019, 08:48 AM Thread Starter
Excellent point IndyVictory! I will keep that in mind.
post #9 of 10 (permalink) Old 04-19-2019, 04:47 AM
Check to see if vent tube, that comes out bottom of bike, is plugged up.
Sent from my SAMSUNG-SM-G930A using Tapatalk
bumpedmyhead is offline
post #10 of 10 (permalink) Old 04-19-2019, 08:12 AM Thread Starter
I saw that drain hole next to the filler opening. I need to find a wire that I can stick down inside of there to see if it’s clogged. Thanks!
Similar Threads
Thread Thread Starter Forum Replies Last Post
Removed tank badge to find tank damage. rescuehazzard Victory Tech and Performance Section 2 06-21-2013 04:39 PM
Gas Tank dent repair or new tank? Bushbee Victory Tech and Performance Section 9 04-26-2011 04:48 PM
Miles Per tank BradT Victory General Discussion 5 02-01-2010 10:15 PM
NOS Tank & Fender set 00/01 V92C 51.50 Motorcycle Parts For Sale / Wanted 0 12-24-2009 08:54 AM
Gas Tank Compatibility EPVictory Victory Kingpin Forum 0 08-06-2009 08:34 PM
