Shell Rotella® T6 15W-40 Full Synthetic Motor Oil - Page 3 - Victory Forums - Victory Motorcycle Forum
 38Likes
post #21 of 70 (permalink) Old 05-30-2019, 02:10 PM
Bueller's Avatar
I didnt like the 5 w 40 version. Very clunky when cold. Must shift down by the book.
I am on Spectro Gold now and have noticed the I can down shift ( anytime ) like a Harley now. Cold Shifts a quiet and shifting is really smooth all around except 1st to second is a little clunk sometimes but that's the nature of the beast. I cant complain.
Magnum USA
Bueller is offline
post #22 of 70 (permalink) Old 06-04-2019, 09:58 AM
SkInM4N's Avatar
I have used the Rotella T6 5w-40 for an oil change but then went back to Mobil 1 full synthetic. This oil change I used the Lucas 20w-50 and it seems to have clunky shifts like it did with the Rotella T6. Perhaps next go around i will source some of the 15w-40 T6
Skin
"Trail is life..."
#rideyoureffingbike
2016 Victory CCT "Miss Pearl"
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
- Taylor Thundervolt wires
- Victory Tri-Ovals (no baffles)
SkInM4N is offline
post #23 of 70 (permalink) Old 06-04-2019, 02:35 PM
Preloading the shifter should eliminate those clunky shifts. I found T-6 way superior to Vic oil and that combined with preloading the shifter, gave me smooth and silent shifts.
post #24 of 70 (permalink) Old 06-05-2019, 09:09 PM
Sunday afternoon I changed my oil and used Rotella T6 15W-40 ($20 a gallon at my local WalMart) with a new filter. In 65K miles, this is the first time I've used anything but Vic Oil. I rode about 40 miles on Monday evening. My CCT still goes THUNK into first, thunk into second and snick at all other times. Exactly like it has for 65K miles. I'm sure the Rotella T6 is great oil but it's not a game changer that I can see or hear yet.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #25 of 70 (permalink) Old 06-05-2019, 09:53 PM
We will never get rid of the clunk into first gear on big V-twins, because the entire clutch assembly is spinning due to oil adhesion. But you can have quiet and smooth shifts if you will preload the shifter and dramatically minimize throttle movement between shifts.
CanuckRob likes this.
post #26 of 70 (permalink) Old 06-06-2019, 01:57 PM
Guys its NOT the oil or clutch plates. Its the shifter drum that is making the clunk. The shifter forks have to follow the groves and make the clunk when they hit bottom. HD and Vic's suck when it comes to this. All the jap bikes have a better design like there clutch pull is superior to Vic's and HD's.
The photo I add here will show you what a drum looks like
https://www.jpcycles.com/product/603...=c&matchtype=e
post #27 of 70 (permalink) Old 06-06-2019, 03:23 PM
Bueller's Avatar
I agree and that is for sure the big source. Its funny that I always wanted one of those Smooth $200 Baker drums for my Buell but as it aged and is working on 50k miles the trans shifts very smooth now. Maybe soon it will grenade! Mobil 1 20-50 vtwin.
Magnum USA
Bueller is offline
post #28 of 70 (permalink) Old 06-07-2019, 04:39 AM
archaicguy's Avatar
Why can I not find this now at Wally World or Amazon? It's oil change time and I thought I would give this a try but......
2016 Cross Country
1969 Firebird
1979 10th Ann. Trans Am
1979 Solar Gold Trans Am
2010 Challenger R/T - Plum Crazy Purple
archaicguy is offline
post #29 of 70 (permalink) Old 06-07-2019, 05:38 AM
vindex1963's Avatar
Bit expensive.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #30 of 70 (permalink) Old 06-07-2019, 05:39 AM
vindex1963's Avatar
better price.
https://www.walmart.com/ip/RotellaT6...llon/869812640
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil report Rotella T 15W/40 vindex1963 Victory Tech and Performance Section 177 08-19-2016 12:01 PM
Victory new synthetic 15w-60 deals? klementa Motorcycle Parts For Sale / Wanted 17 07-09-2016 05:18 AM
rotella t6-5w-40 syn txcanvasback Oil and Lube 90 07-17-2014 02:26 PM
Those using rotella. T6 NJ8BALL Oil and Lube 7 09-04-2012 01:34 PM
From rotella T6 to mobile 1 vtwin back to rotella T6 bL33d Oil and Lube 30 06-21-2012 05:27 PM
