Airbox oil leak?! - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 05-14-2019, 08:51 AM Thread Starter
New Member
Default Airbox oil leak?!
Bought a 2000 V92SC last week. Put 250miles on it with no problems. All of the sudden it's puking oil out of the air box. What the heck is going on??
Jesserupp is offline
post #2 of 4 (permalink) Old 05-15-2019, 01:42 PM
Thats why you have to clean throttle bodys once a year. Pull hose and run it to the ground. Most auto store sell a small filter to put in the end of the hose so you don't get dirt sucked back in.
post #3 of 4 (permalink) Old 05-16-2019, 11:50 AM
Motorbikerx's Avatar
Crankcase ventilation hose feeds into airbox to recirculate the blowby, if your rings arent the best you may have excessive blowby abd oil pumping up into the airbox.
What VJ 's trying to say is disconnect the hose to the airbox and fit a small filter like pictured.
I did that when I fitted Torquetubes.
Overfilling the crankcase oil will result in excessive blowby too.
Its not the end of the world, just take some measures to circumvent it and she will be sweet.
Ride the wheels off it!
Victory!..We Ride!
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 4 (permalink) Old 05-16-2019, 10:06 PM
djh3's Avatar
+1 On over fill crankcase. Every bike I have had since 07 if more than 1/2 way up on fill marks will push oil mist out.
2013 XCT added Jan 2015
djh3 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil Leak from Gear Indicator Switch? dback3 Victory Tech and Performance Section 1 09-30-2010 11:50 AM
2010 hammer s oil leak BIG BLUE Victory Tech and Performance Section 6 09-15-2010 01:03 PM
Oil Leak hwldknights Victory V92C 2 07-25-2010 02:34 PM
oil Leak purple cruiser Oil and Lube 0 07-08-2009 03:10 PM
