Trying to Troubleshoot a clacking sound from front piston exhaust pipe - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 06-20-2019, 03:33 PM Thread Starter
Default Trying to Troubleshoot a clacking sound from front piston exhaust pipe
I have a 2006 Vages with 10,000 miles on it . And there was a very faint clacking sound coming from the front exhaust pipe when I bought the bike. But now that I have put 5000 more miles on the it , it seems a little louder to the point it bothers me .
And Iím trying to find out what is causing this sound . I check the oil psi , 80 psi , check the front cam spring adjuster ,it look good not frozen up. And I check for a loose baffle inside the front pipe. The sound itís not consistent like a valve tapping with the RPMs of the motor itís more of an inconsistent clack clack and then it stops for 2 or 3seconds and does it again . This sound also fades as the motor heats up .
Could this sound be piston slap ?
MattyMoles is offline
post #2 of 12 (permalink) Old 06-20-2019, 05:37 PM
BP6666VR's Avatar
Maybe your hydraulic lifters ?
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 12 (permalink) Old 06-20-2019, 06:32 PM Thread Starter
I did see that as the possible cause in the service manual. But there are no good pictures or info on how to replace them .
post #4 of 12 (permalink) Old 06-20-2019, 07:11 PM
post #5 of 12 (permalink) Old 06-20-2019, 07:53 PM Thread Starter
Possible exhaust leak.
I think its just a bad lifter .
post #6 of 12 (permalink) Old 06-20-2019, 08:15 PM
Oh, I read through this thread too fast. I thought you ruled that out. Yeah; sounds like a weak/bad lifter.
Both of mine will tap like crazy when they have sat for a couple weeks without starting. Goes away as soon as the oil pumps them up. My 2011 sat for a couple of months one time and it took a while for the tapping to go away. Probably 2 miles or so.
post #7 of 12 (permalink) Old 06-20-2019, 08:56 PM Thread Starter
I thought that I ruled out the front hydraulic cam chain tensioner . But I have no way of testing it so if it’s cheap like under 50 bucks I might just buy one . The Hydro lifters are up by the valve springs . What the clacking sound is coming from exactly is a hard thing to determine . Which did you replace the hydraulic cam tensioner‘s or hydraulic lifters in the top in the motor ?
post #8 of 12 (permalink) Old 06-20-2019, 09:18 PM
I thought that I ruled the front hydraulic cam chain tensioner . But I have no way of testing it so if itís cheap like under 50 bucks I might just buy one . The Hydro lifters are up by the valve springs . What the clacking sound is coming from exactly is a hard thing to determine . Which did you replace the hydraulic cam tensionerĎs or hydraulic lifters and the top in the motor ?
I doubt it's the cam tensioner. I guess it could be. Maybe a faulty part from the maker.
It's more likely to be one of the lifters. If it's a front one; it's easy to get at and pull the valve cover.
I didn't replace anything. They just pumped up and were fine.
post #9 of 12 (permalink) Old 06-22-2019, 03:02 PM Thread Starter
I drained the 15/40 oil from it today and replace it with M1 20/50 . Then ran the bike twice about 3 hours apart for a good cool down . And will say there was no change .
post #10 of 12 (permalink) Old 06-22-2019, 06:26 PM Thread Starter
This is the same exact sound but from a different bike , I just got this off of YouTube
Sounds like a loose baffle right .
https://youtu.be/0hCmLSrJXDM
