vegas jackpot tires - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By Motorbikerx
  • 1 Post By half_crazy
post #1 of 7 (permalink) Old 06-26-2019, 10:51 PM Thread Starter
fatcat428's Avatar
Default vegas jackpot tires
hi all
looking for some advice
my tires are 14 years old so its probably time for new ones even though they show very little wear
would you stick with the 250 40 r18 and the 80/90 21
or go fatter in rear and 90/90 up front
thanks for your opinions
fatcat428 is offline
post #2 of 7 (permalink) Old 06-27-2019, 07:36 AM
BP6666VR's Avatar
Originally Posted by fatcat428 View Post
hi all
Yeah change the tires mate
I removed the 250 Dunflop before they were finished so i bought Metz 260/40-18 on the rear ...
But the 260 is actually more narrow then the horrible 250 dunflop ... I hear the 240 Bridstone is SUPER good ....
Then on the front i put a night draggon 90/90-21
But now i run a 160/60-18 on the front, ha ha ha
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 7 (permalink) Old 06-27-2019, 07:37 AM
BP6666VR's Avatar
Ps, maximum tire life is 5 years , and NO CONCRETE PARKING
Sorry for the capital letters
BP6666VR is offline
post #4 of 7 (permalink) Old 06-27-2019, 11:31 AM Thread Starter
fatcat428's Avatar
hi
i was looking at avon 260/40 rear but the 90/90 fronts are bias
is it ok to go bias front and radial rear?
post #5 of 7 (permalink) Old 06-27-2019, 11:41 AM
half_crazy's Avatar
hi
Yes. You won't have much choice.
2006 Victory Kingpin
half_crazy is offline
post #6 of 7 (permalink) Old 06-28-2019, 08:06 AM
Motorbikerx's Avatar
I fitted an XC front wheel 130 70 18 to the front of my Vegas, Bolts straight on,
Youll need the right fender to match though, I raised my skinny one a bit it worked but looked funny.
Then scored a Kingpin USD fork setup and fender and went that way.
Lots of Vic stuff interchanges
BP6666VR likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #7 of 7 (permalink) Old 06-28-2019, 06:19 PM
half_crazy's Avatar
hi all
Your tires have been expired for almost a decade....
If you want the bike to handle better the Pirelli Night Dragon 240mm rear tire will help a lot. Its rounded profile makes the steering lighter.
