200 miles per tank full, almost - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 15 (permalink) Old 07-07-2019, 10:13 PM Thread Starter
rojo154's Avatar
Default 200 miles per tank full, almost
Last week after returning from a long ride I had about 160 miles on the tripometer which I use to tell when to fill up.My 04 Kingpin was good to 120 miles before looking to fuel up, leaving fuel to spare. A couple of rides I took on my 2011 I was going 160 miles plus before gassing up. After the last trip I decided to see how many miles I could go before the low fuel light would come on. So I took a couple of short rides and I was still good at over 180 mi and went out today being sure the light would come on. Well about 10 minutes out and over 190 miles now on the tripometer I started thinking something wasn't right and not 2 minutes later the bike started to miss slightly and I knew. The friggin low fuel light never came on, though it does light up when the key is turned on. Anyway I turned around and kept swerving the bike which got me maybe a mile or so. Pulled of into a parking lot instead of getting stuck on the side of the road. Called my son who brought me some gas. Now I know I'm good to about 140 miles. Hmmm? It might have been a good idea to look in the owners manual for the tank capacity. But who knew the low fuel indicator would be faulty.
2011 Kingpin
custom paint
Ness fly bars
xbow exhaust
S&S air intake
Dobeck fuel controller
chrome floorboards
cruise control
2004 Kingpin
Victory performance exhaust
customized air box / K+N filter
LLoydz fuel controller
custom oil lines
custom led lighting
custom led third brake lights
Sold ..( my baby, still have some sellers remorse)
2011 XC
rpw exhaust
wiseco fuel controller
Sold
rojo154 is offline
post #2 of 15 (permalink) Old 07-07-2019, 10:58 PM
I once ran out of gas and the trip odo showed 246 miles. And that was in some really twisty (switchbacks too) back roads using lower gears.
post #3 of 15 (permalink) Old 07-07-2019, 11:47 PM
vindex1963's Avatar
225 is my best on the Cross Country, I don't remember what the 2004 Vegas would do.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #4 of 15 (permalink) Old 07-08-2019, 12:24 AM
Kinda hard to tell which bike you're talking about that you went 190 miles before running out of usable gas but if it was the 2011 KP with the 4.5 gal tank of which around 4 gal is likely usable; you got 47 mpg.
I don't think that's too bad at all.
BTW; they don't call them "idiot lights" for nothing. They have never been all that reliable and certainly should not be depended on. I'm saying the lights are idiots; not the rider/driver. You're right to use the odometer. On my 04 KP I look for a gas station between 100 and 120 miles just because I know it's not good to run the gas low since it also keeps the pump cool. Especially on hot days.
post #5 of 15 (permalink) Old 07-08-2019, 03:56 AM
Motorbikerx's Avatar
Vegas my light comes on a bit over 200 kms (120 mile) got around 4 litres left.
If I ca accelerate hard and put the light out Ive got at least 2 litres left.
Vegas holds 17 litres.
XC is a different kettle of fish, supposed to hold 23 litres to the baffle, but if Im on the road and riding I can dribble another 2 litres in slowly.
XC light comes on closer to 300 kms but varies according to load, conditions, and my right hand (it's the biggest factor)
Once XC light comes on hard acceleration woint put it out so I guess Ive around 4 litres left.
I get between 14-18 kpl
All this probably means nothing to those still living with gallons and miles.
Use the trip, and dont run it dry too often.
SkInM4N likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 15 (permalink) Old 07-08-2019, 04:36 AM
half_crazy's Avatar
My kingpin ran out of fuel once at 215 miles
2006 Victory Kingpin
half_crazy is offline
post #7 of 15 (permalink) Old 07-08-2019, 09:04 AM
SkInM4N's Avatar
My 2016 CCT gets about 150 miles per tank before the low fuel light comes on...this almost never varies. Loaded, unloaded, trunk, backrest, highway only, stop and go, 2-up, octance ratings, etc. She seems to be consistent across the board. The only big variance I get is during the winter with more warm-up time which makes it worse or on long trips where it gets a little better due to highway only between stops.
I am glad my fuel light comes on but I still start looking at about 140 either way.
Skin
"Trail is life..."
#rideyoureffingbike
2016 Victory CCT "Miss Pearl"
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
- Taylor Thundervolt wires
- Victory Tri-Ovals (no baffles)
SkInM4N is offline
post #8 of 15 (permalink) Old 07-08-2019, 11:26 AM
rainman123's Avatar
My light comes on between 170-180 miles just depends on how hard I'm riding
Chattanooga Mark likes this.
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #9 of 15 (permalink) Old 07-08-2019, 03:09 PM
Dusty Boots's Avatar
If I'm steady cruising around 60-65 mph (100-110 kph) I usually get 315 km (196 mi) before my light comes on, on my 2013 XCT
2013 Victory XCT - SW Ontario
Stage 1 Victory Tri Oval kit, with EFI retune
Lloydz Timing Wheel (+3)
Quarter turn throttle ring
It's never too early to plan and never too late to go!
Dusty Boots is offline
post #10 of 15 (permalink) Old 07-08-2019, 03:59 PM Thread Starter
rojo154's Avatar
Yes, I won't be running it that low again. The last fill up I put about 170 miles on her and the mileage came out to almost 49 mpg. That was going 50 to 55 mph in 6th gear most of the time. I'm wondering if that is too much mpg as they would say on the older bikes that over 45 mpg meant running too lean. I'm going to be installing a Dobeck fuel controller shortly in hopes that will even out my idle and recently I have noticed in 3rd and forth at a steady cruising speed a very slight surging. On my 04 I had this in 2nd gear which the addition of a controller cured. Isn't owning a bike fun. Doing work on the bike is almost as fun as riding it!
rojo154 is offline
