Hyper flash in turn signal - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 07-12-2019, 12:28 PM Thread Starter
Default Hyper flash in turn signal
Reaching out to anyone who has had hyper flash problems on their turn signals.
My turn signals were not working so I replaced the auto cancel module but began hyper flashing on my front-right turn signal and the rear-left does not flash at all.
The left side is fine.
What I am not sure about is the module I purchased, the module is approximately $300.00 but I fount a Victory parts website with what appeared as the original component for significantly less.
It worked fine for a few days but then the problem started.
I don't know if it is the module or something else.
Benito Maldonado is offline
post #2 of 4 (permalink) Old 07-12-2019, 12:55 PM
The right front signal is reverse wired on some models. Since we don't know what model or year we're talking about; you might look into it.
BBob is online now
post #3 of 4 (permalink) Old 07-12-2019, 05:07 PM Thread Starter
It's a 2005 Kingpin BBob
It was working fine until I had to replace the auto cancel module
post #4 of 4 (permalink) Old 07-15-2019, 07:32 AM
New Member
U lost me here, please clarify...
Front right blinks fast, does the rear right blink fast as well, or not at all?
Rear left doesn’t blink at all, does the front left blink fast, blink ‘normal,’ or not blink at all?
Something to consider: if ONE flashed bulb fails to work, its mate at the other end of the bike will hyperblink, the same hyperblink may occur if u replace an incandescent flashed bulb with an LED bulb, this is because the LED unit draws such a small amount of juice, the bike’s flasher circuit thinks it has a bulb out, installing a load equalizer will help with that.
Sempai is offline
