XC Starting issues - Victory Forums - Victory Motorcycle Forum
 9Likes
post #1 of 16 (permalink) Old 08-05-2019, 12:05 AM Thread Starter
Default XC Starting issues
So I was on a ride with the wife today and randomly my bike started turning off and and back on while on the highway. Did this a couple of times and then died all together. Wouldnt start again and nuetral and oil light were flashing. Got it home in a truck and got the battery charger then tried to start again.
The link is a video of what it was doing and the sound it was making with the kill switch on and off. The noise sounds like it's coming from behind the motor... any ideas?
https://youtu.be/aLIkSaXtlGA
2013 Cross Country, Nuclear Sunset Orange
Trioval Exhaust
Arlen Ness Deep Cut Grips
Orange13 is offline
post #2 of 16 (permalink) Old 08-05-2019, 02:34 AM
There's a breaker on positive side of the battery. Replace it. $5 part at NAPA. Also; how old is the battery. Can you pull it and have it load tested?
visionjohnny and 541RF like this.
post #3 of 16 (permalink) Old 08-05-2019, 11:25 AM
541RF's Avatar
I do not have an XC, but when my battery started to get weak the bike ran bad and it would not start if the battery volts was 10 or less. Every thing else worked fine, but no start and some times would not turn over. New battery installed and all is good. Just some info. Check what BBob said first.
Good luck,
541RF
2004 Arlen Ness Signature Series Vegas
Black-Cherry Fade
Stage one dealer kit installed
Bags, tour seat with backrest and rack
Southern, OR.
541RF is offline
post #4 of 16 (permalink) Old 08-05-2019, 01:06 PM
Something I just noticed but should have seen right away in the video is your volt gauge on the dash is reading zero with the key on. Pretty sure you should be reading at least 12 volts. I'm too lazy right now to go out to the garage and check though.
visionjohnny and Motorbikerx like this.
post #5 of 16 (permalink) Old 08-05-2019, 05:45 PM
Jakvis's Avatar
After reading about all the breaker issues, I've always wondered if it wouldn't make sense to just change the breaker at the same time you change out a battery. The breaker is certainly cheap enough.
You could always keep the old breaker as a spare if it was working ok when you removed it. I do this with my spark plugs, figuring if I ever cracked a plug while cleaning or doing maintenance I wouldn't be stuck without my ride.
Current Stable: 2014 XC, Honda PCX 150, 125 SYM Havana.
Born in the deepest jungles of India, I was raised by a friendly bear, until I was kidnapped by a pack of unruly baboons who taught me the finer points of swing jazz, all the while being stalked by an incompetent python and an evil but mis-understood tiger... Ummm, wait a minute, that's the Jungle book, no I was raised just outside of St. Louis, But...in the deepest jungles of a middle class neighborhood .
Jakvis is offline
post #6 of 16 (permalink) Old 08-05-2019, 06:50 PM Thread Starter
So I removed 2 relays were doing the clicking and voltage on the dash matched voltage on the meter, around 12.8 even after messing with this for a while, battery will drop down to around 7 but is back to around 12.8 within 30 seconds of shutting the bike off.
The battery should be around 13 something if I'm not mistaken right?
Trioval Exhaust
Orange13 is offline
post #7 of 16 (permalink) Old 08-05-2019, 07:44 PM
I'm at around 28k on my XC and still using the original breaker at the battery. I do have a spare in my saddlebag though.
SemperVee and RoteBaron like this.
post #8 of 16 (permalink) Old 08-05-2019, 07:46 PM
13.8v if memory serves. Again; how old is the battery? I'm guessing it's time for a new one.
RoteBaron likes this.
post #9 of 16 (permalink) Old 08-05-2019, 08:09 PM Thread Starter
Yeah I think the battery is gone. The bracket didn't fix it. I don't know how old the battery is but it's the same 1 since I bought the bike back in early March
Trioval Exhaust
Orange13 is offline
post #10 of 16 (permalink) Old 08-05-2019, 08:10 PM Thread Starter
Breaker not bracket
Trioval Exhaust
Orange13 is offline
