Won't rev past 3900 plus no gear indicator - Page 2 - Victory Forums - Victory Motorcycle Forum
 8Likes
post #11 of 23 (permalink) Old 08-10-2019, 03:13 AM
BP6666VR's Avatar
Originally Posted by Splodge View Post
Bike is a 2015 HighBall, Lloydz torque tubes with K&N's, Bassani Pro turn outs, PCV, (set up on Dyno), MSD ignition, Lloydz timing wheel (4deg), WYRD XV40 Cams.
Bike starts, shows N for neutral, but once in gear and moving shows a dash (-). And then hits a rev limiter at just under 4k.
I've tried disconnecting the clutch switch and the speed sensor, still the same.
Beginning to think it is the PCV
Any help would be greatly appreciated.
Did you wash the bike ? Ride the bike around the block a bit under 4000 k rpm ...
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #12 of 23 (permalink) Old 08-10-2019, 03:46 AM Thread Starter
Splodge's Avatar
It was at the end of a ride, first started happening. Some of the ride had been in very fine drizzle, but bone dry and sunny when it occurred.
BP6666VR likes this.
Steve
England UK
2015 HighBall
Splodge is offline
post #13 of 23 (permalink) Old 08-10-2019, 09:12 AM
Clutch lever pulled in bike will show the '-' and I believe that also puts it into neutral rpm limit which is below the other rev limits.
I'd check your lever clutch switch just for giggles.
post #14 of 23 (permalink) Old 08-10-2019, 09:31 AM Thread Starter
Splodge's Avatar
I disconnected the switch and went for a ride, still the same.
Steve
England UK
2015 HighBall
Splodge is offline
post #15 of 23 (permalink) Old 08-10-2019, 11:03 AM
Was worth a try.
post #16 of 23 (permalink) Old 08-10-2019, 12:17 PM
That's normal when you pull in the clutch lever. You should only see the gear number when the clutch is out or partially out.
At least that's the way it works on the XC. Been so long since I had a newer steel frame bike; I don't remember what it did on my 09 JP.
I wonder what we did when all we had was a speedo, maybe a tach, and some idiot lights if we were lucky.
post #17 of 23 (permalink) Old 08-10-2019, 06:04 PM
My Honda only has a speedo, and couple idiot lights for oil and temperature.
My thought was that if the bike is seeing that clutch switch pulled in (through short or something) that it would be causing the issues OP is having. I know the default programming on the CCT has a much lower rev limit in neutral so probably same on all 106.
It seems simple enough to just disconnect that add-on system and see if the issue goes away.
post #18 of 23 (permalink) Old 08-11-2019, 02:47 AM Thread Starter
Splodge's Avatar
First post at top , says I have already disconnected the clutch switch, got the same results.
Steve
England UK
2015 HighBall
Splodge is offline
post #19 of 23 (permalink) Old 09-02-2019, 02:45 PM
https://www.thevog.net/threads/remov...-do-not.59339/
^ disconnecting clutch switch limits RPM in all gears.
I was trying to say in my response your clutch switch probably messing up not working correctly.
FWIW my clutch switch seems to have died so I'm in the same boat. Can't rev over 3900ish and no gear indicator. Not getting the usual audible clicking sound from it as the lever moves the arm. Might try disassembly as I have nothing to lose now.
post #20 of 23 (permalink) Old 09-02-2019, 04:31 PM Thread Starter
Splodge's Avatar
I did totally disconnect it, still wouldn't rev.
It is booked in next week at a Polaris dealer, so they can plug their Digital Wrench into it.
Hopefully it will be something simple.
Steve
England UK
2015 HighBall
Splodge is offline
