oil - Victory Forums - Victory Motorcycle Forum
post #1 of 23 (permalink) Old 04-15-2013, 01:55 PM Thread Starter
Default oil
Oil has always been a top topic. Owning numerous Harleys, the oil topic was no different, what brand, what weight etc. After reading all I could find, I decided to use Mobil one V-twin in all my Harleys. I now own two victories, and on this forum, oil is still very talked about. Harleys use 20-50, and Victories use 20-40. Again, I read a lot about what to use in a Victory, and still not sure what to use. My question is, do or should I use 20-40, or can I use 20-50, like the mobil v-twin. Don't have a dealer close to me, so I would like to use the mobil 1. Some say the victory was designed to use 20-40, others say 20-50 is fine. So, yes or no on the mobil v-twin?
oldrocker is offline
post #2 of 23 (permalink) Old 04-15-2013, 02:17 PM
Lostintexas's Avatar
Oh my.
Well, if it is a lagit question, here goes. I'm not very familiar with the M1 20-50, but it may not be compatible. "Harley" engine oil doesn't mix with the clutch and could cause slipping if it contains friction modifiers.
The oil could be a bit heavy too. Just because it is a twin doesn't mean all twins use the same viscosity. Oil and engine engineering has come a long way so there just isn't a need for the syrup of days gone by. Thinner is the new fashion due to better oiling and smaller oil ports. The 50 weight shouldn't hurt per say but will be less than optimal.There is also the very harsh transmission environment that comes into play and may not be good with certain blends.
Do what you want, yo will find the opinion you like and follow it anyway, but stay with a wet clutch compatible blend that has good resistance to shear. Most JASO MA oils are fine and there are pretty much enough flavors to satisfy the masses.
Welcome the the mayhem.
I ride with the Force.
Lostintexas is offline
post #3 of 23 (permalink) Old 04-15-2013, 03:33 PM
i'm nearing oil change time and have been debating the subject. I think I will listen to the person that probably knows more about vics than anybody but the designers, and maybe even them, lloydz. I don't have a local dealer either but ups comes here.
now , 2011 crossroads and 05 sportster bobber in the making
in order of ownership, sears compact scooter, honda 305 scrambler, honda 160 dream , triumph 500 trophy trail, honda cb450, sportster, honda f750, 2nd sportster, harley flh, harley super glide, 3rd sportster, bmw k1000, harley low rider, 2nd harley super glide, harley heratage, harley road king, bmw r1150rt,
thats just the street bikes!
ridealittle is offline
post #4 of 23 (permalink) Old 04-15-2013, 04:11 PM
Smile
Castrol Actevo 20-40. A semi synthetic that meets Victory requirements...
SemperVee is offline
post #5 of 23 (permalink) Old 04-15-2013, 06:00 PM
PLEASE PLEASE go to top of page click on forum scroll down to oil there is over a good hundred post there
post #6 of 23 (permalink) Old 04-15-2013, 06:30 PM
You should stick with a 40 weight. The first number could vary from 5w to 20w, but do your engine like the engineers designed and stick with 40.
Pick up some shell rotella triple 15w40 from Walmart. $13 a gallon.
2012 Victory XC
2000 Harley Dyna FXD
cocheese72 is offline
post #7 of 23 (permalink) Old 04-16-2013, 07:08 AM
PhilC64's Avatar
The next person who posts an oil thread without searching should be have their hands beaten with mallets.
2015 XCT - Flying lounge chair
PCV, ATS +4, Lloydz filter, VM1-HPT cams, and Freedom True Duals.
2004 King Pin - 100 cid Big Bore, Ness Intake, Victory Performance Exhaust
2010 XR - Road toy
PCV, ATS +4, Lloydz filter, VM1-DR cams, and Freedom True Duals - traded
Cam Swap write up for X Series bikes:
https://docs.google.com/open?id=0B95...YW1XVXFpeU9fUQ
PhilC64 is offline
post #8 of 23 (permalink) Old 04-16-2013, 08:15 AM
Buellx72's Avatar
http://www.lloydz.com/techtip.asp?ti...20to%20use.inc
Sent from Motorcycle.com App
2012 Cross Country Tour Sunset Red
Lloydz air filter
PCV w/ AT
D&D wrapped pipes (unwrapped now)
2013 Vision Tour
'07 Road King Sold
'00 Buell X1 Sold
'72 Sportster (In Pieces)
Buellx72 is offline
post #9 of 23 (permalink) Old 04-16-2013, 08:19 AM
Bad V V's Avatar
Lol lol.
So what kind of oil should I use in my victory?
PS: I only used my thumbs to type this post.
2003 Victory vegas
Bad V V is offline
post #10 of 23 (permalink) Old 04-16-2013, 02:48 PM
I've used Mobil 1 in every motorcycle I've owned for the past 15 years. Before they made bike specific Mobil 1, I used the the standard automotive version. Most of these bikes were sport bikes where the transmission gears were shearing thorugh the oil with the engine above 10K rpms a good bit of the time, and I never had any problems with any of them. I've heard the speculation that you can have wet clutch problems, but that hasn't been my experience with sport bikes, dual sports, or v-twin crusiers. In fact, every single bike I put any type of Mobil 1 in has ran cooler and shifted much smoother.
Since my Vegas is the first Victory I've owned, I don't have any experience with using 50w in the engine. It is ready for an oil change, and if the only appropriately weighted Mobil 1 is of the automotive variety, I won't hesitate to use it.
07Vegas is offline
