Broken oulet from the fuel pump - Victory Forums - Victory Motorcycle Forum
post #1 of 20 (permalink) Old 04-26-2013, 03:12 AM Thread Starter
theteese's Avatar
Default Broken oulet from the fuel pump
Hi Guy's.
I have done the most stupid thing and broken the outlet plastic tube on the fuel pump under the tank whilst trying to remove the stupid clip.
I just rang the dealers and got a quote for $695 for a new fuel pump ( Made in fkn China ).
Has any one else done this and can it be glued, welded ( or anything else ) back together ?
Any suggestions would be appreciated.
Even if anyone knows what ype of plastic the fuel pump cover is made of would be helpful.
Cheers
AL
Vegapot - 2009 Vegas Lo Custom, A Bitsa of an Exhaust, Mustang Solo Seat, Jackpot 250mm Rear End, Stage I Upgrade, Highball Mini Apes, Alen Ness Bullet Turn Signals, Power Commander V, Luv Ridin it.
theteese is offline
post #2 of 20 (permalink) Old 04-26-2013, 04:55 AM
GatorJoe's Avatar
Don't Really have a good Answer for you other than this.. Sure Wish someone would make an Easy Fix for this as have heard of it happening too often .. Although have removed my tank 3 times with no mishaps, Scares me every time I do it ... A Good Machinist should be able to sell an Adapter plate with the Nipple like Hotcakes at a Lumberjack Breakfast
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #3 of 20 (permalink) Old 04-26-2013, 08:05 AM
Tarzan's Avatar
Drill and tap for a pipe thread. Get a brass nipple and thread it in. That's what I would do.
There is a guy on another forum that made a plate with a nipple.
'14 Ness XC
Tarzan is offline
post #4 of 20 (permalink) Old 04-26-2013, 08:06 AM
gibson's Avatar
1 7517515 Screw 1 Usage
1 7518086 Screw 3 Usage
1 7517845 Screw 1 Usage
1 4011080-385 Asm., Ignition/Fuel Cap, Silver 1 Usage
1 4011080-266 Asm., Ignition/Fuel Cap, Black 1 Usage
2 1015931-266 Tank, Fuel, Spine 1 Usage
2 1015931-1264 Tank, Fuel, Spine 1 Usage
2 1015931-564 Tank, Fuel, Spine 1 Usage
2 1015931-566 Tank, Fuel, Spine 1 Usage
2 1015931-520 Tank, Fuel, Spine 1 Usage
2 1015931-1270 Tank, Fuel, Spine 1 Usage
3 7517525 Screw 3 Usage
4 5136665 Bushing, Flange 3 Usage
5 5412480 Bushing 6 Usage
6 7556260 Washer, Flat 1 Usage
7 7547233 U-Nut 1 Usage
8 5412415 Cover, Mount, RH 1 Usage
8 5412414 Cover, Mount, LH 1 Usage
9 5413346 Seal, Fuel, Molded 1 Usage
10 2521169 Pump, Fuel 1 Usage
11 7518923 Screw 10 Usage
12 5413413 Line, Fuel, Tank to Fuel Rail [For 9.5 mm Fuel Tank Fitting] 1 Usage
12 5414150 Line, Fuel, Tank to Fuel Rail [For 11.8 mm Fuel Tank Fitting] 1 Usage
13 7081151 Clamp, Hose 2 Usage
14 5435764 Line, Water Drain 1 Usage
15 5437376 Line, Fuel Vent 1 Usage
16 5435771 Line, Water/Fuel To Ground 1 Usage
17 2520909 Asm., Filter, Fuel
https://www.google.com/webhp?rls=ig#...w=1508&bih=874
2012 Fireball Jackpot
gibson is offline
post #5 of 20 (permalink) Old 04-26-2013, 02:39 PM
Your not the lone ranger here are a bunch any maybe a fix.
http://www.bing.com/search?q=broke+g...PERNSB&PC=PE05
post #6 of 20 (permalink) Old 04-26-2013, 05:38 PM Thread Starter
theteese's Avatar
Hahaha,
Nice pic Gibson but of no actual use. ( Sealed Unit )
Refer to other answers.
Cheers
AL
theteese is offline
post #7 of 20 (permalink) Old 04-26-2013, 05:40 PM Thread Starter
theteese's Avatar
Thanks VJ,
Excellent reply / help,
On the way to the machinists now to get a fix.
The most interesting bit was the costs that others had paid for a new fuel pump in USA v's my quote of $700.
Cheers
AL
theteese is offline
post #8 of 20 (permalink) Old 04-26-2013, 05:42 PM Thread Starter
theteese's Avatar
Thanx Tarzan
theteese is offline
post #9 of 20 (permalink) Old 04-27-2013, 06:15 AM
gibson's Avatar
Originally Posted by theteese View Post
Hahaha,
Cheers
AL
I was just showing you part numbers, so you can fend for yourself for now on..
gibson is offline
post #10 of 20 (permalink) Old 04-27-2013, 02:53 PM Thread Starter
theteese's Avatar
Thanx,
But i think we all know,
http://parts.polarisind.com/Browse/Browse.asp
As stated i did my home work and it's a sealed unit.
Thanx to all those that knew what my problem was.
Cheers
AL
theteese is offline
