4.5 Quart Oil Change Kit - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 06-01-2013, 08:51 AM Thread Starter
Default 4.5 Quart Oil Change Kit
It seems not everuone is aware Victory has a 4.5 quart oil change kit "For All 100 & 106 Cubic Inch Engines". It's under part number 2879600 and retails for $59.99.
The kit includes:
4 One Quart containers of Victory Semi Synthetic 20W-40 oil, item number 2879601
.5 Quart of Victory Semi Synthetic 20W-40 oil, item number 2879602
1 Polaris Oil Filter, item number 2540086
1 large copper crush washer, item number 7556039
1 large rubber o-ring, item number 5412020
1 small copper crush washer, small zip lock bag, no item number
Thank You,
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #2 of 4 (permalink) Old 06-01-2013, 10:42 AM
Hey, that's great! I could sure use that zip lock bag. Thanks for the info.
Whereabouts in Chicago do you live? I lived in Rogers Park until my folks moved us to the NW when I was 12--a few years ago. Gotta stuff myself at Manny's every time we're back there.
post #3 of 4 (permalink) Old 06-01-2013, 05:31 PM
Goatlocker95's Avatar
I buy the 5 qt oil for $44, black filter for $13, and the crush washer for $1. Pretty much the same cost as the 4.5 qt kit. I save the extra .5 qt and then after the 9th service the oil is free
2014 Indian Chieftain
Goatlocker95 is offline
post #4 of 4 (permalink) Old 06-01-2013, 08:24 PM
GatorJoe's Avatar
With the miles I put on still get the 6 quart deal .. Every 3rd change just need to buy a filter and always keep a stack of washers on hand ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
