Bike is too hot - Victory Forums - Victory Motorcycle Forum
post #1 of 23 (permalink) Old 06-18-2013, 01:55 PM Thread Starter
bcflyguy's Avatar
Send a message via MSN to bcflyguy
Exclamation Bike is too hot
Has anyone tried to take off the heat shields on their XCT and wrap the exhaust then replace the Shields? These pipes are getting hotter by the minute. Can't stand it anymore. What is the solution??? Any ideas out there
Thanks in advance
bcflyguy
Kelowna British columbia Canada
1 2012 cross country tour arlin ness big honkers/ fuel controler/air mod, Bag rails, Ostrich 2 up custom seat, Sheepskin seat cover, trunk rack. Bag locks
2 2013 cross country tour . Trunk removed. ness honkers lloydz air box, bag rails Rich's custom gel/ ostrich seat .Bag locks. chrome pass boards. Ignition relocate.Kury mirrors,
bcflyguy is offline
post #2 of 23 (permalink) Old 06-18-2013, 02:04 PM
ridinman's Avatar
I took the deflectors out of my bike last year when it got hot. Put them back in when it got cool.
Here's a thread about it. I think it helps, others have their own opinion.
https://www.victoryforums.com/showthread.php?t=12322
Ride Safe, Ride Often
Life's to short to be GRUMPY
Bill
2014 XCT
Lenexa, KS
ridinman is offline
post #3 of 23 (permalink) Old 06-18-2013, 04:26 PM
Have you tried opening the lowers up only an 1" or so? I don't know myself but I've heard others say about them that less is more when it comes to keeping cool. I'm kind of looking forward to expermenting with that a little more the next time I get to do some demo rides. It's also controversial about removing the cats from the exhaust to move the heat out of the exhaust quicker. I removed my right side cat and bent the diverter plate in the cross-over pipe forward and over so that it blocks a lot of the cross pipe and most of the exhaust comes out the right side in more of a 2 into 1 fashion. I think it helped mine run cooler and if I lost any torque I can't feel it so i would have had to dyno before and after to know. I will say the motor revs more freely and responsive now than before. I have the S1 mufflers so they are wide open if you look through them. I don't think I would do that with stock mufflers.
40XC is offline
post #4 of 23 (permalink) Old 06-18-2013, 04:31 PM
Lostintexas's Avatar
+1 on closing down the vents. An inch to start then make very small adjustments till good.
These bikes have a reputation for being very lean. It might be a possiblity you are too lean. A dealer check may be in order. Hope you have a good dealer, they seem to be hard to come by.
Cheers
I ride with the Force.
Lostintexas is offline
post #5 of 23 (permalink) Old 06-18-2013, 04:37 PM
Yes guys have wrapped the pipes and a little better feeling.
Your Major heat comes from the motor. Your sitting on a oven in a manner of speaking.
post #6 of 23 (permalink) Old 06-18-2013, 08:16 PM Thread Starter
bcflyguy's Avatar
Cheers
I Have Arlin Ness big honkers and fuel controller as well as a lloydz air box. Could this be the reason????
It was a lot cooler stock. I THINK!!!!!
bcflyguy is offline
post #7 of 23 (permalink) Old 06-18-2013, 08:23 PM Thread Starter
bcflyguy's Avatar
Yes ,Vision johnny, I am sitting on an oven but I don't want to burn my cookies LOL
bcflyguy is offline
post #8 of 23 (permalink) Old 06-18-2013, 08:56 PM
XKnight's Avatar
More air and a properly adjusted fuel controller should make the bike run cooler, not hotter. Could it be that with summer temps in play you are just feeling the engine heat more than before?
XKnight is offline
post #9 of 23 (permalink) Old 06-18-2013, 09:36 PM Thread Starter
bcflyguy's Avatar
That could very well be. Also age does not help. Would it help if I took off the lower leg fairings completely??
bcflyguy is offline
post #10 of 23 (permalink) Old 06-18-2013, 10:46 PM
I ran the Victory lowers for a while and found them to be too hot during the summer to leave on. I picked up some JTD lowers and found they could be left on during the summer so I sold the Vic lowers and stuck with the JTD lowers and the forged crash bars.
Last Summer I started making some leather heat shields for this reason. They have sheet metal sandwiched between layers of leather so they can be molded up to a point. They are in my sig line and I do ship to Canada for whatever extra it happens to cost. Takes a while to get there though. Just depends on how customs is doing I guess. Could be 2 weeks could be longer. I just sent out my last ready made one so I need to get busy and make some more now that the heat is settling in again.
