Cruise Control works as it should! - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 07-23-2013, 09:24 PM Thread Starter
sixshooter_45's Avatar
Wink Cruise Control works as it should!
I've experienced first hand and have read on this forum where the cruise control does not work well when it was previously set to a lower speed and it's set again at approximatley 5 mph faster.
I have found out in the last few weeks that it in fact will pick up even 1 mile faster than the previous setting and all you have to do is hold down the set button for 1 second for it to work.
I just got lucky one day and thought I'd give it a try, it works great and every time even at 1 mph faster even though you may have to go 2 mph faster prior to pressing the set button but this was just a test to see if it would actually work below 5 mph and it does at least on my bike and I'm sure on all others also.
Just thought I'd share.
sixshooter_45 is offline
post #2 of 3 (permalink) Old 07-23-2013, 09:52 PM
your return cable might be set to tight
post #3 of 3 (permalink) Old 07-23-2013, 10:50 PM Thread Starter
Talking
I don't think you understood my post, I don't think I have a problem.
Many others stated that once a cruise speed was set that a 5mph higher one didn't want to take on a quick press of the set button which is the same way mine was.
I believe that I have already checked the return cable when I was setting the throttle cable more to my liking and if I recall it was resetting properly as it had slack in it off throttle.
If your implying that pressing the set button should take on a "quick press and release" when the cruise set button was pressed previously and is active, then I'll recheck the return cable slack.
