What Is This On My Engine? - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 09-06-2013, 04:54 PM Thread Starter
Big Tav's Avatar
Default What Is This On My Engine?
I was just looking over my bike and I noticed this shiny silver spot on my black engine which looks like it has had something removed from it and now there is an exposed thread so I am worried about rust and what (if anything) is missing.
Hear from you guys soon!
2015 Highball Black - Mods being done now!
Suzuki M109R L0 - Sold
BMW K1200R - Sold
Suzuki TL1000R - Sold
2014 Victory Hammer S - Sold
2012 Victory Highball - Swept Pipes, RPW Baffles Stage 1, 02's Removed, Lloydz Timing Wheel 4+, 1/4 Turn Throttle Ring, Mini Bullitt LED Indictors, Kewl Metal Brackets, Arlen Ness Pegs & Grips, Arlen Ness Cam Cover, K&P Oil Filter, Magnetic Sump Plug, Rear Axle Covers, Black Engine Bolt Kit. - Now Sold :(
Big Tav is offline
post #2 of 9 (permalink) Old 09-06-2013, 05:32 PM
That is where the battery ground connects on a cross bike. Nothing fell off it an unused bolt hole on steel frame bikes.
99 Kawasaki Vulcan 800 (sold)
2012 Vegas (traded)
2013 Cross Country Tour
Victory Tri-Ovals, Reverse Kit, Lloydz air filter, Lloydz quarter turn throttle ring, PCV, Lloydz Touring cams, HMD Bars, DGD keyless ignition, Rockford Fosgate Amp, klockworks windshield. 119hp 123lbs torque.
jchris56 is offline
post #3 of 9 (permalink) Old 09-06-2013, 05:34 PM
SilentUnicorn's Avatar
OMG- you have lost the thermal differential inter-spatial hierarchy for linear engine cohesion dohickey. Do not ride that until you replace it.
Just kidding. I put a p-clip and routed the alt wire thru it to clean it up.
https://www.victoryforums.com/showthread.php?t=34490
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
post #4 of 9 (permalink) Old 09-06-2013, 10:04 PM
Roadrocket's Avatar
Aluminum doesn't rust
The Truth is Often Painful
2011XC
Roadrocket is offline
post #5 of 9 (permalink) Old 09-07-2013, 03:26 AM Thread Starter
Big Tav's Avatar
What is the best bolt to go in it? I don't want water to sit in it.
BMW K1200R - Sold
Big Tav is offline
post #6 of 9 (permalink) Old 09-07-2013, 04:13 AM
Its an m6 x really short.
post #7 of 9 (permalink) Old 09-07-2013, 04:52 AM Thread Starter
Big Tav's Avatar
This might sound silly but is that US spec or would it be the same M6 in the UK?
BMW K1200R - Sold
Big Tav is offline
post #8 of 9 (permalink) Old 09-07-2013, 05:07 AM
dtmmil's Avatar
m6 would be a metric bolt 6mm diameter.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #9 of 9 (permalink) Old 09-07-2013, 05:19 AM
Correct, m6 x 1, I had an 8mm long one and I ground a bit off to make it fit without bottoming out. I would also suggest just a small dab of never seize on the threads to help prevent corrosion between the aluminum case and steel fastener. This is an area that could get fairly wet, and water could get in the hole even with a bolt in it.
m
