Dain's Kuryakyn Brake Pedal - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 10-02-2013, 12:31 PM Thread Starter
Default Dain's Kuryakyn Brake Pedal
Dain's Kuryakyn break pedal. The rubber pads are easy to replace and readily available from Kuryakyn when the time comes to replace them.
The pedal comes preassembled and all you have to do is remove the stock brake peg and install the new pedal with the supplied bolt. No drilling and ruining the brake arm. This install takes five minutes from start to finish and you are done.
Victory 1 is offline
post #2 of 19 (permalink) Old 10-02-2013, 12:39 PM
Cool. Where did you get this? I'd be worried how sturdy that angle bracket is...
post #3 of 19 (permalink) Old 10-02-2013, 12:54 PM Thread Starter
You can get them here, he is a Victory rider as well. The pedal is very solid and does not give or bend at all.
http://www.ebay.com/itm/Victory-Visi...-/150735968775
post #4 of 19 (permalink) Old 10-02-2013, 05:40 PM
dtmmil's Avatar
I was interested till i saw how it bolts on. If i get a brake pedal i will get a matching shifter but i have to be able to shift from the bottom of it. I dont(wont) use a heel shifter.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 19 (permalink) Old 10-02-2013, 06:07 PM Thread Starter
You may like these from Kuryakyn, they are longer than the stock Victory pegs and look a whole lot better. They use a bolt that goes all the way through the peg and bolts to the stock shift and brake levers.
http://www.kuryakyn.com/products/920...ift-brake-pegs
I thought I would not like a heel shifter but I have changed my mind after buying the Victory brand heel shifter it sits out of the way and is always right there when you need it. It allows you to use the entire floorboard without crowding your foot in any way.
http://www.purepolaris.com/en-us/Vic...arisPGACatalog)
Just because it shows up in the photo you may like the FMB choppers Victory shift rod. It is a nice heavy duty highly polished part that is of high quality.
http://fmbchopperparts.com/victory-c...ft-p-2769.html
post #6 of 19 (permalink) Old 10-02-2013, 06:22 PM
These guys have a lot of options for shifters and brake pedals...
http://buywitchdoctors.com/index.htm...s&search=shift
2013 Hammer 8-Ball
Flame Bandit Seat
RPW Thor Exhaust
S&S Intake
PCV with Autotune
2" Control Extension
MBW LED Turn Signals
Side Mount License Plate
Infidel is offline
post #7 of 19 (permalink) Old 10-02-2013, 06:23 PM
SilvrT's Avatar
hmmmmmmm... looks good but ... does it improve your braking any?
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #8 of 19 (permalink) Old 10-02-2013, 06:31 PM Thread Starter
Actually over the stock peg that comes with the bike yes it does improve the braking. The feel is much better and this pedal is in the right place compared to the small peg Victory uses on the bikes.
Victory should be using this pedal from the factory.
post #9 of 19 (permalink) Old 10-02-2013, 06:57 PM Thread Starter
post #10 of 19 (permalink) Old 10-02-2013, 07:01 PM Thread Starter
This company offers several neat shift linkages.
http://www.cycleopsusa.com/custombillet.html#shl
