Help, I made a mess of my pipes :( - Victory Forums - Victory Motorcycle Forum
post #1 of 31 (permalink) Old 10-15-2013, 11:18 PM Thread Starter
KNielsen's Avatar
Default Help, I made a mess of my pipes :(
Sooo in typical me fashion, I had a pretty major brain fart today. I looked down and there was part of a leaf on my pipes, so me not wanting anything touching my pipes I went to brush it off.... With my glove on... while they were hot...
So now instead of having a leaf just sitting on my pipes not bothering anybody I have a big glob of rubber that melted off my glove to the pipe.
I let it cool off once I got home and try to lightly buff it out with jsut a rag and some water. Nothing. So before I went and put anything else on them I wanted to ask around before I went to bed for the night, Does anyone have a remedy to get miscellaneous junk off of chrome pipes without scratching them or ruining the chrome?
07 Kingpin
Bob Dron Fairing
Dakota Digital Tach
L.E.D. Tail Light
H.I.D.s
Stage 1 Shotgun Pipes
1/4 Turn Throttle
KNielsen is offline
post #2 of 31 (permalink) Old 10-15-2013, 11:27 PM
Sniff around Google for: Easy Off (Cold) Oven Cleaner. Usually does the trick, just be careful what you use to rub at it with because you don't want to scuff up the chrome.
TeamG is offline
post #3 of 31 (permalink) Old 10-15-2013, 11:35 PM
SilvrT's Avatar
double-O steel wool and a good quality chrome polish will work.
Before that though, try using some lacquer thinner to "melt" the rubber down.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #4 of 31 (permalink) Old 10-15-2013, 11:38 PM
JonW's Avatar
Check the local auto parts store for Goo Gone or a similar product. No matter what you use, let the product do the work. It may take repeated applications. Keep rubbing to a minimum to avoid scratching the chrome.
2013 Victory Cross Country Tour
Sunset Red
2" pullbacks, Tri-ovals, Madstad shield, TVS tuned
2014 Harley-Davidson Road King
Brilliant Silver
JonW is offline
post #5 of 31 (permalink) Old 10-16-2013, 07:47 AM
smoke's Avatar
Can of air (for cleaning keyboards etc)
Turn it upside down and spray it so the extreme cold will quickly freeze the rubber and chip or pick it off with a fingernail quickly.
Works for gum in carpet too. (recommended from a buddy that owns his a carpet cleaning business.
Smoke XC
2013 AntiFreeze Green
D&D exhaust, Gust. Smoke +2 Flip or 7" Dk Smoke shield, Kickers with Rockford Fosgate Amp, Vic Pass. Backrest & lots of extra chrome.
2011 Victory Blue XC - Traded
2007 Honda Blue VTX - Traded
smoke is offline
post #6 of 31 (permalink) Old 10-16-2013, 07:55 AM
Steel Wool will scratch chrome, I've used 000 before and it will scratch also. Do what Smoke said!
diamonbird is offline
post #7 of 31 (permalink) Old 10-16-2013, 07:58 AM
dtmmil's Avatar
Ive done the steel wool before without problem, use chrome polish or wd-40 or something with it though.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #8 of 31 (permalink) Old 10-16-2013, 08:04 AM
ccrainman's Avatar
Goo-gone or WD-40 should do the trick.
ccrainman is offline
post #9 of 31 (permalink) Old 10-16-2013, 09:43 AM
NOEMTZ's Avatar
Easy off works for me everytime.
www.noemtz.com
NOEMTZ is offline
post #10 of 31 (permalink) Old 10-16-2013, 09:49 AM
SilvrT's Avatar
and I've used OO on chrome for well over 30 years and not once have I scratched the chrome so, I guess it's a matter of who's doing it eh? LOL
That said tho, smoke does have a good idea which I've never tried.
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
