Help!! - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 12-28-2013, 06:27 AM Thread Starter
keithpix's Avatar
Default Help!!
I pulled the kingpin in the garage on Monday. I went to start it yesterday and the starter turns over but it won't start. I'm wearing down the battery. Any thoughts?
keithpix is offline
post #2 of 15 (permalink) Old 12-28-2013, 06:40 AM
GatorJoe's Avatar
Fuel Pump Start when Power Up? Plug Getting Fire ?
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #3 of 15 (permalink) Old 12-28-2013, 06:46 AM
I always have to use fast idle and sometimes blip the throttle just a tad (try to keep the rpms as low as possible) in order to start mine when it is colder than 25 F.
2004 Kingpin Chapin, SC
DanG144 is offline
post #4 of 15 (permalink) Old 12-28-2013, 07:13 AM Thread Starter
keithpix's Avatar
No luck. I get a pop one time like it wants to start but then nothing.
keithpix is offline
post #5 of 15 (permalink) Old 12-28-2013, 07:33 AM
BruceI's Avatar
How cold is it in your garage? I remember the days when bikes had kick starters. In the winter months, even when the electric starter sounded normal, I would often have a bike that would not fire a single shot. One kick on the kick starter and the bike would be running. If I was planning on riding regularly in extremely cold temps, I'd be shopping for a bike that has a kick starter. For now, I'll just leave the bike parked if temps aren't somewhere near forty degrees. After a recent morning of -35, I guess I should state forty degrees above zero!
2012 Cross Country Tour
2008 Royal Star Venture
BruceI is offline
post #6 of 15 (permalink) Old 12-28-2013, 07:43 AM
NJ8BALL's Avatar
Did you try cycling the key to activate the fuel pump a few times? Mine cranks a bit longer if my iav is closed to much in the cold.
'09 Kingpin 8-Ball...Sanded chrome exhaust, Stage 1 slipons, VFCIII, Lloyds IAV, Stonny's 27" sissybar, Edge bags with ghost brackets,Kuryakyn black ISO grips,
http://www.bluebeardimagery.com/
http://blue-beard-imagery.artistwebsites.com/
Photo equip: Canon 60D, Canon 55-250is, Canon 18-55, Canon 70-200f4,Tamron SP10-24
NJ8BALL is offline
post #7 of 15 (permalink) Old 12-28-2013, 07:51 AM Thread Starter
keithpix's Avatar
I did recycle the shut off switch 4 times but still nothing. The fuel pump is running. I can hear it when I turn on the key. It is about 45 degrees in the garage.
keithpix is offline
post #8 of 15 (permalink) Old 12-28-2013, 08:06 AM
slickvic's Avatar
How old is the fuel? If its older than a month and it's Ethanol 10% remove it and put fresh fuel in. Change the plugs while your at it. Only $3 a piece.
slickvic is offline
post #9 of 15 (permalink) Old 12-28-2013, 08:12 AM Thread Starter
keithpix's Avatar
Fuel is 93 octane and is about 2 months old. Funny thing is it ran great on Monday.
keithpix is offline
post #10 of 15 (permalink) Old 12-28-2013, 08:26 AM
Goatlocker95's Avatar
Simple things I've run across starting Victory bikes in the cold
Check that the battery terminals are tight
Ensure the battery is fully charged
Crack the throttle just a little bit (an 1/8 of an inch or less) when hitting the starter
If it still won't start did you do anything that might've caused a problem when you put it away? Did you pressure wash the bike and maybe got some water in some places it doesn't belong like the plug caps, ignition or kill switch? If you think there might be then squirting a little WD-40 can displace the water.
If that's good then narrow down whether you have a spark problem or a fuel problem. I pull both plugs and look at them. If it's wet with unburned fuel, it's a safe bet that the plug is either fouled, or you've lost the spark. To check the spark ground each one to the chassis then look for sparks when you hit the starter. Don't keep cranking or you'll flood the engine. If there is a problem then you'll have to find out why you don't have a spark.
To check for a fuel problem pull the fuel line off the throttle body and aim it into a glass jar. Cover the opening so gas doesn't splash out then hit the kill switch. Gas should gush out.
Beyond that you probably have to do a compression or leak down test.
2014 Indian Chieftain
Goatlocker95 is offline
