Indicator Mount Advice? - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 01-13-2014, 04:58 PM Thread Starter
Big Tav's Avatar
Default Indicator Mount Advice?
I am looking at getting some new front indicators for my Highball and I need to figure out which mounts to go for. I going to get these indicators:
http://www.ebay.co.uk/itm/1511975954...84.m1423.l2649
I have to decide which mounts to get. Vic Only have these: http://www.victoryonly.com/ACCESSORI...ght_mount.html
Kewl Metal have these: http://www.kewlmetalstore.com/produc...roducts_id=750
I can see the Kewl metal ones work and I know you can see the wiring a bit.
What I can't figure out is how the VicOnly ones run the wiring. I can see they fit nice and flush on the forks but how does the wiring work?
What do you all think I should go for?
2015 Highball Black - Mods being done now!
Suzuki M109R L0 - Sold
BMW K1200R - Sold
Suzuki TL1000R - Sold
2014 Victory Hammer S - Sold
2012 Victory Highball - Swept Pipes, RPW Baffles Stage 1, 02's Removed, Lloydz Timing Wheel 4+, 1/4 Turn Throttle Ring, Mini Bullitt LED Indictors, Kewl Metal Brackets, Arlen Ness Pegs & Grips, Arlen Ness Cam Cover, K&P Oil Filter, Magnetic Sump Plug, Rear Axle Covers, Black Engine Bolt Kit. - Now Sold :(
Big Tav is offline
post #2 of 3 (permalink) Old 01-13-2014, 05:52 PM
garandiver's Avatar
Send a message via AIM to garandiver
Looks like on the Vic mounts that the wiring take a hard 45 degree turn. If you look closely, you can see that there seems to be a drilled out area for the wiring to go out the back. I think the Vic mounts look better but it is certainly up to each person's taste. Good luck. I do like the lights you have picked out.
[SIGPIC][/SIGPIC]thumb up
2006 Hammer Custom
Grand Rapids, Mich.
garandiver is offline
post #3 of 3 (permalink) Old 01-13-2014, 05:58 PM Thread Starter
Big Tav's Avatar
Thanks for the reply. Just looking at the pictures again. I am not sure if the indicator thread is right size to go through the whole on the Viconly ones either?if that hole is 9 mm and the indicators have a 10 mm thread that is them out of the question right?
BMW K1200R - Sold
Big Tav is offline
