Tire help! - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 01-17-2014, 06:51 PM Thread Starter
jokerman's Avatar
Question Tire help!
Getting close to 20K on my OEM front tire & looking for recommended replacement. I definitely want something that will last up to 20K like the Dunlop. My major issue is the handling in the tar snakes, With a rider on the back, running thru the twisties on fresh tar snakes, I had my hands full....felt like I was driving on ice! My son runs a Metzler on his front & had the same experience, plus I know the Metz is not known for high mileage. I am considering going Bridgestone, based on past experience on a Jap bike, or maybe looking at the new Michelin Commander. However I have heard that the Mich is biased ply & if that is the case, I would not even consider it.
I am open to any suggestions gang. Riding a 2012 Vision.
Thanks!
JOKERMAN
"THERE IS NO SUBSTITUTE FOR VICTORY" General Douglas MacArthur
jokerman is offline
post #2 of 14 (permalink) Old 01-18-2014, 02:54 PM
gibson's Avatar
If the Dunlop lasted that long , what makes you think another brand would last longer?
2012 Fireball Jackpot
gibson is offline
post #3 of 14 (permalink) Old 01-18-2014, 03:16 PM
DIDN"T you ask this just the other day
post #4 of 14 (permalink) Old 01-18-2014, 03:17 PM
saddlebag's Avatar
Thanks!
You should add your bike to your sig for more specific replies.
A general response is that you aren't going to find a tire that sticks on hot tar snakes. Stick your finger in freshly chewed gum and move it to the right. Your finger won't slide on the gum, if the gum is gooey, it will change forms under your finger. The same thing happens when you run over a hot tar snake.
There is plenty of internet folklore of certain brands of tires sticking on all kinds of surfaces like wet paint. Watch a motorcycle road race in the rain sometime. Those guys are using the grippiest rubber compounds known to man and they will slide right into the sand traps everytime they hit it. What are the odds we are going to do better on some tire compound that is compromise between grip and longevity?
2011 Cross Roads
saddlebag is offline
post #5 of 14 (permalink) Old 01-18-2014, 09:15 PM Thread Starter
jokerman's Avatar
I guess it is forbidden to post more than 1 thread? Gee, sorry.
JOKERMAN
jokerman is offline
post #6 of 14 (permalink) Old 01-18-2014, 09:18 PM Thread Starter
jokerman's Avatar
Saddlebag, it clearly states I am on a "12 Vison in my post. Anyway, I never really thought of the tar snakes the way you describe them. Really makes a lot of since. Perhaps I should not nock the Dunlops after all.
JOKERMAN
jokerman is offline
post #7 of 14 (permalink) Old 01-18-2014, 10:44 PM
Default Get what you want
If you want the Avons go for it. I have the Avon Venoms on my XRs now. Will they last as long as the Dunlops? Hopefully, but if they do not I will probably get the Avons again. But go with the brand you want, and if they make you happy great if not, try that other brand. Good luck on those tyres!
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #8 of 14 (permalink) Old 01-19-2014, 04:39 AM
GatorJoe's Avatar
Give Avons a Shot .. Can always go back to OEM if not happy with them .. Love the Avon Cobra's on my 12 XC ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #9 of 14 (permalink) Old 01-19-2014, 08:17 AM
vindex1963's Avatar
Just put Avon Cobras on my Vegas seems good but they always do when you replace old worn out tires with brand new ones.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #10 of 14 (permalink) Old 01-19-2014, 11:57 AM
You can post all the thread you want BUT you did ask the same question some time back
You didn't get the answer you wanted so now your posting it again.
Why did you just keep the old thread going.
