Joe Florida Led lights installation - Victory Forums - Victory Motorcycle Forum
post #1 of 25 (permalink) Old 02-01-2014, 03:01 PM Thread Starter
Default Joe Florida Led lights installation
I purchased a set of Joe Florida led lights for my 2013 Cross Country Tour. I have installed the front wheel,tank and rear wheel lights. I am having a small issue on how to install the set that goes under the engine. The only area that would hold the lights would be the oil pan but with the heat of the hot oil pan ,I don't know if this is a wise choice!
If any one has any suggestions on how to install them in this area that would be helpful.
Rocketman
Rocketman is offline
post #2 of 25 (permalink) Old 02-01-2014, 03:28 PM
Encmerk's Avatar
Perhaps zip ties to lower frame rails? This would keep you just outside the oilpan. If you place them slightly inside they won't show, but will give good light effects.
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
post #3 of 25 (permalink) Old 02-01-2014, 05:36 PM
smoke's Avatar
Yep, Done it twice.
Use a 9 volt battery and get the LED strip lit up.
Mess around with the angle but they will shine both on the lower part of the engine and for ground effect lighting if you place them sort of under/inside the floorboards.
Make sure to clean the area very well and I have had no problems with them in that spot at all.
Smoke XC
2013 AntiFreeze Green
D&D exhaust, Gust. Smoke +2 Flip or 7" Dk Smoke shield, Kickers with Rockford Fosgate Amp, Vic Pass. Backrest & lots of extra chrome.
2011 Victory Blue XC - Traded
2007 Honda Blue VTX - Traded
smoke is offline
post #4 of 25 (permalink) Old 02-03-2014, 07:26 PM Thread Starter
Default Joe Florida Led Installation
Smoke, Thanks, for the tip! I'll give it a try . With all the controls on the in the way it look a bit complicated. Where did you make all the connects once you finished all the wiring? Of course with the battery being up front all my wires are running forward so they are near the battery before I connect the fuse and battery.
Did you place the rear wheel LEDs under the frame under your rear bags or did you connect them directly to the rear bags? If so how did you hide the wires?
post #5 of 25 (permalink) Old 02-03-2014, 08:45 PM
Micg1313's Avatar
Talking
Please post some pictures when your done .
Micg1313 is offline
post #6 of 25 (permalink) Old 02-04-2014, 03:27 AM
gibson's Avatar
http://www.walmart.com/ip/StarTech.c...ounts/13215650 I use mounting stick blocks under tank to mount lights and run the wires.
2012 Fireball Jackpot
gibson is offline
post #7 of 25 (permalink) Old 02-04-2014, 07:16 AM
smoke's Avatar
I took the wire under the floorboard mounting brackets into the motor area and up under the tank and back. Actually ran the rt side over to the left to get away from the exhaust heat via down through the battery area. At night you can use a 9 volt and light the strip to see the reflections etc.
Back strips I put under the bags toward the outsides. There is the "lip" under there. I shine them towards the chrome exhaust and they reflect off towards the ground. Only problem is it makes a dark shadow under the exhaust closer to the bottom of the tire. So to help that area I put small strips on the metal exhaust framework that comes from the rear fender area out to the saddlebags. Run wires up inside rear fender.
TIP: use some of Florida Joes disconnects for the saddlebag LED's. I put mine at the place the Ipod cord comes out from under seat and jumps acrossed to the saddlebag mounting frame. Zip tied between the seat and frame. Put the connection there. When you undo the mounting screws to remove the bags simply get the LED connection too.
Anything else I can help with just yell.
Smoke XC
smoke is offline
post #8 of 25 (permalink) Old 02-04-2014, 07:42 AM
Are you using the strips or pods under the bike? I've used Joe Florida and he has some good stuff. I'm in the middle of installing a kit right now too, I'm adding the flat strip style and in the front I liked the bottom edge of the floor board mount for the best location of the light to shine where I wanted and mount flat.
The 9vt and tape is a great way to figure it out, I taped on strips a bunch of times to figure mine out. Still not 100% on how I want to light the engine as you can see the bottom of the tank and the strips show but I've got time to figure it out.
I'll have a picture thread up when I'm done too.
2012 Victory Cross Country Tour, Sunset Red.
Parts added to make her louder, faster and more mine.
Stage 1 filter and pipes, Lloydz VFIII & ATW.
Clearwater Darla, LED GLO, emergency lights and siren.
Bushtec hitch and harness, Kompact Kamp trailer.
ChuglyXJ is offline
post #9 of 25 (permalink) Old 02-04-2014, 08:33 AM
smoke's Avatar
I use all strips. I had a few pods to try and didn't care for them as much as strips.
Strips can be twisted or curved slightly to cover an area a little better than pods.
You can cut some of Joes strips in multiples of 3. Only the ones that have double ends but this makes fitting in some places nicer.
Smoke XC
smoke is offline
post #10 of 25 (permalink) Old 02-06-2014, 07:18 PM Thread Starter
Smoke, thanks for the advice. I am going to attach the Road Coverage kit led lights to the inside edge of my foot boards.I think this will do the trick. This should move me along nicely to completion.
