Snap-On LED Turn Signals Review - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 02-11-2014, 11:02 PM Thread Starter
Default Snap-On LED Turn Signals Review
I received a set of the Snap-On turn signals from Justin over at newragecycles.com the other day and i decided that i would do a mini writeup and review of them since i have not seen anyone on here with them.
First i chopped off the pigtail off of the stock turn signal (will not use those things again)
Strip a small amount off the end of the pigtail then plug it into the bike and make sure the the wires are not touching anything.
Put a multimeter on the wires to make sure which wire is the +12v and which one is ground. (failure to do this could fry your auto cancellation module)(BLACK WIRE ON THE STOCK SIGNALS IS NOT ALWAYS GROUND)
Strip equal lengths of both wire and solder them together (i chose to use heat-shrink instead of electrical tape because it will last much longer and do a better job of keeping moisture out
Here is what it looks like when it is lit up (very bright, motorists should have no problem seeing this. keep in mind i bought one of those self adhesive led strips and tried to use those and you could not see them in the daytime)
As you can see they blend in really well when they are off.
In my mind these are great for the money and the build quality is great. I have included a link to the product page if anyone is interested.
http://www.newragecycles.com/Snap_On...snap-front.htm
2014 Pearl White Cross Country
Ketis is offline
post #2 of 12 (permalink) Old 02-12-2014, 06:36 AM
Encmerk's Avatar
Great review. They look just like a set I helped a friend put on his Vegas 8 ball, but don't require you to slide fork tube out of top triple tree! It appears to be a very easy install! Thanks.
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
post #3 of 12 (permalink) Old 02-12-2014, 09:45 AM
Konga63's Avatar
They look very clean. I'm waiting on some Show Chrome Torpedo signals myself. Can't wait to get rid of the stocks as they are pretty lame IMO. I am also planning to do exactly what you did with the stock harness. Makes the reinstall easy. Thanks for the pics.
2007 Ness Jackpot
Konga63 is offline
post #4 of 12 (permalink) Old 02-12-2014, 10:13 AM
KNielsen's Avatar
What size did you order?
07 Kingpin
Bob Dron Fairing
Dakota Digital Tach
L.E.D. Tail Light
H.I.D.s
Stage 1 Shotgun Pipes
1/4 Turn Throttle
KNielsen is offline
post #5 of 12 (permalink) Old 02-12-2014, 10:16 AM Thread Starter
Id check your owners manual for the fork diameter (not sure if they changed over the years)
but on my 2013 Vegas it was 43mm
Ketis is offline
post #6 of 12 (permalink) Old 02-12-2014, 10:28 AM
KNielsen's Avatar
Will do, these would look sharp under the mini fairing i have. thanks for the post
07 Kingpin
Bob Dron Fairing
Dakota Digital Tach
L.E.D. Tail Light
H.I.D.s
1/4 Turn Throttle
KNielsen is offline
post #7 of 12 (permalink) Old 02-12-2014, 11:52 AM
Konga63's Avatar
Default Fork Dia
Fork dia's on the Vic's are 43mm (jackpot, vegas...) and for the inverts, I believe they're 56mm though not certain.
2007 Ness Jackpot
Konga63 is offline
post #8 of 12 (permalink) Old 02-12-2014, 08:05 PM
XzombieX66's Avatar
Do you know of any videos? i would like to see them blinking with the Amber/white lights.
Big Gonzo Mufflers
Lloydz adjustable timing wheel
Ness RAD III Mirrors, Ness Deep cut grips
Vic Hids, Vic Baggers Tarzanz Bars +1 rise +2 pull
Vic Baggers 6.5 degree triple trees
Gorby's Machine 23 inch wheel- Windmill contrast cut,
23 inch wrap around front fender, Whitewall choppers Radio control Bezel and 1.5in Lowering link...
XzombieX66 is offline
post #9 of 12 (permalink) Old 02-12-2014, 08:09 PM
Travis P's Avatar
What Xzombie said.
Sent from Motorcycle.com App
Travis P is offline
post #10 of 12 (permalink) Old 02-12-2014, 10:08 PM Thread Starter
I do not. I got the regular amber flashing ones.
Ketis is offline
