Quick Gas Tank Question - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 02-21-2014, 04:32 PM Thread Starter
Default Quick Gas Tank Question
I need to get a an inch more space to get at the throttle linkage and was wondering if I can left the back of my gas tank up about an inch without having to remove it?
I have the seat off and it looks like if I removed the two back tank bolts I could prop the back of the tank up a bit. Is this true or am a off base. Thanks for a quick response.
2013 Cross Country - Antifreeze Green
Cottage Grove, Minnesota
VM1-DR Cams
Power Commander
Lloydz air filter
Timing gear
1/4 throttle
Dyno tune from the Vic Shop
107.44 HP
108.03 Torque
MN Victory is offline
post #2 of 4 (permalink) Old 02-21-2014, 04:54 PM Thread Starter
If you can't tell I'm new to Victory. Always rode Yamaha and knew those bikes inside and out. Not a huge learning curve but they certainly are different.
VM1-DR Cams
Power Commander
Lloydz air filter
Timing gear
1/4 throttle
107.44 HP
108.03 Torque
post #3 of 4 (permalink) Old 02-21-2014, 05:46 PM
SilvrT's Avatar
Yes, just lift it up and stick a short piece of 2x4 in there.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #4 of 4 (permalink) Old 02-21-2014, 05:47 PM Thread Starter
Great. Thanks for the tip!
VM1-DR Cams
Power Commander
Lloydz air filter
Timing gear
1/4 throttle
107.44 HP
108.03 Torque
