Trailering long distance w/o wheel chocks - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 03-03-2014, 05:48 PM Thread Starter
Dennisfarrell80's Avatar
Default Trailering long distance w/o wheel chocks
Hello All,
I searched but didn't really find anything on this topic. I am in process of moving from Chicagoland to Raleigh, NC and cant wait to get back in the saddle after a terrible winter. I am using UHaul truck, a car hauler and ordered a M/C trailer but come to find out the M/C trailers are only available for local use. So they are going to give me a "ramp" trailer. It does not come with and I can't mount a chock. This will be the first time that I have trailered my XC. I have trailer previous bikes but always on a trailer set up with chocks. Does anyone have experience w/o chocks? Problems or not? Tips, etc.
'13 Black XC
Bassani 2>1
Lloydz intake and VM-1
T.V.S. tuned PC-V
Dennisfarrell80 is offline
post #2 of 15 (permalink) Old 03-03-2014, 05:58 PM
Send a message via Yahoo to mrtappan Send a message via Skype™ to mrtappan
Driven many bikes, many miles without them. In fact never used them. ratchet strap on each fork/triple tree and one through the back tire. Never had a problem
Current toys:
2013 Victory Hardball - VM1DR cams, Lloydz filter, timing wheel, PCV-AT, 1/4 turn throttle, modified pipes
2008 Yamaha Warrior -Churchkey intake, V&H Bigshots
2007 Scion TC 5spd
1997 F150 -used to pull my car hauler
1989 Nissan Hardbody -absolutely indestructible
1968 Coupe Deville -all black, so nice
mrtappan is offline
post #3 of 15 (permalink) Old 03-03-2014, 06:02 PM
stick the front wheel in the corner of the trailer so it can't move side to side. side to side is what you don't want
post #4 of 15 (permalink) Old 03-03-2014, 06:24 PM
Hemidan's Avatar
you can still use a chock,you just have to strap the chock down.
I'm assuming the trailer your renting is Aluminum so you cant mount the chock?
I just rented a uhaul(aluminum trailer) and thats what I did.
Strapped the chock down then strap the bike down.
I put the chock against a few pieces of wood,so the fender wouldnt hit the front of the trailer
2010 CR - D&D pipes unwrapped / Lloydz Performance Cams / Lloyd'z Idle Air Valve / Lloydz Adjustable Timing System / Lloydz Hi-Flow Air Filter / PCV w/AT / Vintage Mustang Seat w/backrest / Lock Ride Passenger Backrest / Powerlet Handlebar Outlet / Lay down License Bracket / Adjustable Drop Bracket
Avon Velvet Air Cushion Gatlin Grips/DERBY COVER & CAM COVER SET/Beacon LED Headlight Black
Phase 7 L.E.D. 4-1/2" Passing Lamps/Sabertooth Taillight Accents
Hemidan is offline
post #5 of 15 (permalink) Old 03-03-2014, 07:07 PM
Hemidan, your license bracket is on its way. Thanks for buying one. Which Hemi do you have? I have a 2007 Chrysler 300C in Arrest Me Red. What a great machine.
post #6 of 15 (permalink) Old 03-03-2014, 07:18 PM
Sponkey#1's Avatar
I have mounted a chock to a two by six with eye bolts in it to attach ratchet straps to. Strapping the board down and the the bike does a good job of immobilizing everything. Not the best option but it is an option.
Sent from Motorcycle.com App
2012 Vegas Eight ball
Ride hard. Ride safe.
Sponkey#1 is offline
post #7 of 15 (permalink) Old 03-03-2014, 07:20 PM
Hemidan's Avatar
Thanks
I have the older one...2004 2500 Dodge Ram with 37" tires and a 6" ish lift....and I love it...Thank god its not my daily driver....gas would kill me...
Hemidan is offline
post #8 of 15 (permalink) Old 03-03-2014, 07:37 PM
Hemidan's Avatar
I also used these handlebar straps,too
http://www.ebay.co.uk/sch/items/?_nk...d=596299349284
Hemidan is offline
post #9 of 15 (permalink) Old 03-03-2014, 09:06 PM
fargoben67's Avatar
I have never used a chock. I put the strap around the fork above the lower triple tree and then hook the strap back to itself. I also like to wrap a white cotton rag around the fork to prevent the strap from leaving any marks. I used red ratchet straps on a brushed aluminum fork once. I could never get these small red marks out. I also like to try to hook rear straps to the frame vs the tire. If you can compress the suspension a little it will bounce less going down the road. Less bouncing means less of a chance something will loosen or move. And NEVER be afraid to use too many straps. You can't be too carefully. If you have no bags you could put a strap over the passenger seat. If you put it over the driver seat it has a bigger seat pan and I've seen those bend slightly on long trips with a tight strap over it. I've hauled over 3,000 pieces of John Deere farm machinery. I haven't lost anything yet. I work for the local dealer here. When in doubt, add a strap.
2013 Highball (for me)
Torque Tube intake - VFCIII - Hacker Lake Pipes - Lloydz PTS set at +4 - Blinkers and License plate holder stripped - Side mount plate
2008 Kawasaki Vulcan 500 (for her)
2008 Suzuki Boulevard M50 (miss it)
1989 Kawasaki Ninja 500 (RIP)
Never underestimate the power of stupid people in numbers.
fargoben67 is offline
post #10 of 15 (permalink) Old 03-03-2014, 09:08 PM
fargoben67's Avatar
Check your straps after the first 50 or so miles and then again every time you stop.
