Check Engine Codes - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 06-23-2014, 09:45 AM Thread Starter
Exclamation Check Engine Codes
Hey All,
It's been a while since I posted, want to say hey and hope all is well! I've been doing some research and I've found some great information, but really need some clearing up when it comes to specific codes I've got on my 2013 Victory Highball.
A couple things first: I have a Cobra PowerPro CVT Fi2000, stock exhaust with baffles removed.
I was riding Saturday and received the following codes: 0 17 520204 and 1 17 520205. I took it down to my local Victory dealer and had them run the codes, seems as though I was running lean in both cylinders. The tech cleared the codes, I started my bike and was prompted with 0 17 520204, not 1 17 520205. The tech said that my bike was still running lean and he would look into it. After informing him about the PowerPro, he immediately began bad mouthing the CVT and told me that was my issue, and that I should take it off. I thought to myself this was a possibility, so I asked him to clear the codes one more time and I would journey home to remove the CVT. During my trek home, the codes came and went. When I got home, there were no codes on the bike at all, nothing in the readout and no other issues. I decided to leave the CVT on and continue riding. Since Saturday, I've put on up to 100 miles and I've not seen the codes come back at all, with the CVT still on it.
I'm curious if anyone has some ideas, information, or knowledge about this? I would really appreciate the assistance!
Thanks
-HT
2013 Victory High Ball
"Lola"
Cobra Fi2000 PowerPro
Bassani Pro Street Turnouts
K&N Filter
Amsoil Synthetic
HunnieToast is offline
post #2 of 13 (permalink) Old 06-23-2014, 10:15 AM
Sorry for your problems but the net shows a lot of them
http://www.bing.com/search?q=problem...c=IE-SearchBox
post #3 of 13 (permalink) Old 06-23-2014, 01:08 PM Thread Starter
I've looked, and I understand that they have issues, just as anything else in life obviously. But if there is anyone that has more information, I would greatly appreciate it.
"Lola"
K&N Filter
Amsoil Synthetic
post #4 of 13 (permalink) Old 06-23-2014, 01:12 PM
It's true; those codes are occurring probably because the Cobra unit is confusing the main ECU. I was getting the same codes. I know one way to resolve this is to unplug your O2 sensors. Just don't use them. Tie up all of the extra cabling and get it out of your way. You may also be able to carefully open up the Cobra unit and turn up the adjustment dial a little bit. You can probably call Cobra and they will help you out.
I have adjusted my dial in the unit and I might even try to plug in the O2 sensors again for the hell of it to see what happens...
post #5 of 13 (permalink) Old 06-23-2014, 01:19 PM Thread Starter
Thanks Broggyr!
I really appreciate that! I may sound dumb, but does unplugging the O2 sensors cause any issues? Like am I at risk of ruining my Victory?
Also, I found this post (https://www.victoryforums.com/showthread.php?t=13848) , and I've been reading it over and over again, still trying to wrap my head around it all. I called cobra today, but the tech was on lunch. I will be calling again shortly.
"Lola"
K&N Filter
Amsoil Synthetic
post #6 of 13 (permalink) Old 06-23-2014, 01:43 PM
I've been running my O2 plugs off now for over a year. No issues for me. Without them, the engine runs a tad richer. One of the first things we learn to do as new Vic owners is to unplug those pesky O2 sensors
There are many many posts about unplugging the O2 sensors.
post #7 of 13 (permalink) Old 06-24-2014, 08:23 AM Thread Starter
So a little more on this issue...
I live in New Mexico, where the temperature likes to fluctuate on occasion, for instance yesterday our high was 97* and the low was 65*, at 3pm MT we were hit with rain showers and the temp dropped roughly 10 degrees in 3-5 minutes. Today's forecast is 100* for the high and 69* for our low.
With all that said, yesterday morning rode to work at 6am and had no issues with codes. I took my lunch around 11am when it was much warmer in the day and my Highball threw both codes again. Got back from lunch and parked it, left work at 3pm and no codes yet again.
I've yet to get in a hold of anyone at Cobra, but I did leave my contact information with their voice mail services.
Any further suggestions, ideas, or knowledge on this? I will most likely be doing my O2 sensors here soon, as suggested.
Appreciate it!
-HT
"Lola"
K&N Filter
Amsoil Synthetic
post #8 of 13 (permalink) Old 06-24-2014, 08:58 AM
slickvic's Avatar
HT, Broggy is correct with his approach to help you. In numerous conversations it has been determined that the Victory ECU gets confused by the presence of the cobra unit with O2's connected. The way I ran mine (when I had one) was to run with the Vic only (factory) O2's connected. Leaving the Cobras O2 harness wrapped up and put away. Why is it there then? Think EPA.
You may also just run no O2 connections at all. This will not harm your bike but may produce more pooping on decal as it will richen you mixture a tad. Running no baffles at all may give your bike a lack in back pressure which will make popping even more present. Try the above scenarios and check with Big city thunder for a set of performance baffles for you pipes They are well designed and if you like loud pipes they will not disappoint. If you don't already have it, get an kit designed for your bike as well. Disconnecting O2's has been proven to create no harm to your bike. Again think EPA.
slickvic is offline
post #9 of 13 (permalink) Old 06-24-2014, 09:17 AM Thread Starter
Thanks Slick! I read the post you had about 2 years ago with the same issues, that's where I've been trying to get the most information from for these codes! My exhaust, to explain as best as I can, is the stock tips cut to 14 inches, slash cut with no baffles. Not sure if I can get baffles for them at this point. When you suggest a kit designed for my bike, are you speaking to the exhaust kit specifically? I will check out Big City Thunder as well, I'm pretty sure I've been there a couple times looking at items.
Thanks again!
"Lola"
K&N Filter
Amsoil Synthetic
post #10 of 13 (permalink) Old 06-24-2014, 01:30 PM
slickvic's Avatar
Thanks again!
Its ok that you cut your pipes back. The BCT baffles are about 5" long and if you can slip them up into the pipe about 6 " then you can just drill a small hole behind the pipe and secure them there with a nut and bolt. I have them on my VTX1300c with Jug Hugger pipes and they made an incredible difference in mid range power. They will help with torque, are a little deeper in sound compared to a spiral core baffle and sound incredible.
The kit I was referring to was an air kit. Check Lloyds site if you do not have one. If you cant get right with the Power Pro then your next purchase should be the PCV IMO. Get the baffles and air kit 1st before you invest more into the fuel tuner. Save up cause you will need a DYNOTUNE too. Then I have no doubt you will be a happy Victory owner.
slickvic is offline
